AgTalk Home | ||
Anyone know this guy selling pipe? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forums List -> AgTalk Cafe | Message format |
Jon V |
NW Iowa | I am looking for a semi load of well pipe, and was wondering if anyone had dealt with this guy out of Rockwell Texas? Thanks Jon https://dallas.craigslist.org/dal/grd/d/2-3-8-oilfield-fencing-fence... | ||
Drilldo |
Texas | It ain’t pipe and it ain’t drill stem. That is upset tubing. I would not pay that much for used tubing. Should be able to find new reject tubing in that price range. When the oilfield sells tubing it is because it is no longer fit for them to use. Salt water runs through it and it will rust from the inside out over time. I will also add rock wall isn’t near the oil patch. Edited by Drilldo 8/13/2018 17:49 | ||
Drilldo |
Texas | Here is a good read for you. http://gobobpipe.com/howtobuypipe.htm | ||
Jon V |
NW Iowa | Thanks for the link! so is this stuff worthless than? or is it ok for the right price? | ||
bshannon |
. | Thanks for posting that link. I was thinking of getting some pipe, had no clue about the saltwater and rod rubbing insides of pipe. Won't be buying any sight unseen now. | ||
Galaxie64 |
WY, OK | Since distance apparently isn't an issue try: http://meritenterprises.com/ Out of Tulsa back about 10 years ago they were worth a trip from WY built our entire new corral system with their stuff. Also a few good places I know in CO if that isn't too far: These guys test pipe, all theirs is clean and in good shape have bought lots of it there: http://www.rockymtninspection.com/Drill_Pipe_Inspection/Welcome.htm... And have bought some from these guys: http://www.rpjenergy.com/ | ||
Southern Farmer |
West Texas | I built my corrals and gates out of 2 3/8 oilfield pipe that came from stripper wells. The above article is correct. I have many spots that have rusted through during the past 22 years. Sometimes this pipe is subject to crowding but I have had no trouble with any of it collapsing with the cow and bull pressure. $33 sounds pretty high to me. | ||
DR24 |
NECO | I have some 3 1/2" Nat gas pipe in classifieds | ||
Drilldo |
Texas | Jon V - 8/13/2018 19:15 Thanks for the link! so is this stuff worthless than? or is it ok for the right price? It is a crap shoot really. I have two semi loads of pipe fence at my place. Most of it is the reject new pipe but some is used. I don’t remember off the top of my head the color codes but most used tubing is tested by the oil companies before selling it. They check (X-ray maybe? ) for wall thickness and it either passes and they keep using it or it fails and they sell it off. There are different degrees of failing represented by different markings. Some used pipe is ok and virtually all of it will be fine for some period of time but stuff that is badly worn won’t last. The labor costs more than the material so at least in my eyes it makes sense to buy good pipe and have it last a lifetime instead of having to redo it ten years down the road. By the way I have no affiliation with go bob and I think their prices are high but they have some very good info. If you get the livestock weekly newspaper there are usually a lot of pipe advertisements in there for big pipe yards that likely have some reject pipe. | ||
Jon V |
NW Iowa | Thanks for all the advice guys. I have a truck that will be in Texas Wednesday, so I would like to make something work from that direction. | ||
Jim Ed Love |
Indian Territory | Check them out. wheelermetals.com and they will deal on a truck load. Right on the way back home to I O Way Edited by Jim Ed Love 8/13/2018 22:36 | ||
Funacres |
Texas | I would look for some plastic lined pipe. It is abundant if you ask for it and you won't have any trouble working with it once you learn how. Edited by Funacres 8/13/2018 23:54 | ||
IADAVE |
Just a thought on used pipe. Isn't the potential there to be radioactive? | |||
eight |
South Texas | Usually better deals on pipe in Oklahoma. | ||
shadetree |
NW South Dakota | Yep, don't ever use oil field pipe to build a stripper pole. Most other uses its fine. | ||
Southern Farmer |
West Texas | IADAVE - 8/14/2018 01:41 Just a thought on used pipe. Isn't the potential there to be radioactive? Yes, Our local salvage requires all scrap metal to come through a radiation detector. If the alarm goes off, they will ask you to circle around and come through it again. If the alarm goes off again, they will not buy that load. | ||
ntexcotton |
North Central Texas | For this area http://jimfg.com/ Or http://fluscheenterprises.com/ | ||
Funacres |
Texas | Most pipe dealers will have a geiger counter to check for radiation because they don't want to buy it themselves. | ||
nwokman |
GoBob is some good info but remember he is trying to sell you what he has. I have oil field tubing that’s been in the corral for over 30 years and none of it has rusted. Stay away from tubing that has a plastic lining or has concrete in it. You can find good 2 3/8 for .75 per foot. Lots of 2 3:8 and 2 7/8 Used around here for corrals, posts, corners, buildings, trusses. | |||
(Delete cookies) | |
