Search Forums | Classifieds (103) | Skins | Language
CIH air seat switch failure. Anybody got a better solution?
Adrian
Posted 6/26/2018 20:45 (#6836072)
Subject: CIH air seat switch failure. Anybody got a better solution?
South Georgia
The air line fitting blew out of the seat switch in the 3330 sprayer today. I'm 99% sure it's the same switch as Deere uses, but there may be some minor differences. These things don't last that long, seems I replace one in something almost every year. Does anybody have a source to get them significantly cheaper than Deere and CIH? There's a Sears part number on it, but I didn't really find much better prices by googling that number. CIH wanted about $50, and I'm pretty sure Deere is in that ballpark for theirs, too. That's nuts for something so small with such a high failure rate in my opinion.
Also, they all fail exactly the same way, but I guess they don't have to do better, I keep buying them anyway.
Adrian
(6950.jpeg)
Attachments 6950.jpeg (131KB - 96 downloads)
Fingers77
Posted 6/26/2018 20:59 (#6836112 - in reply to #6836072)
Subject: RE: CIH air seat switch failure. Anybody got a better solution?
That switch in the picture is from 2011, so it's kinda old. It still shouldn't fail, I agree.
It's available from any truck shop worth its salt, I think about 45 bucks. I have part numbers at the shop.
Email me in the am, I'll look up my info on them, I can't find the post I thought I gave the information on. Maybe I didn't post it, I thought I did.
NMO Redpower
Posted 6/26/2018 21:02 (#6836126 - in reply to #6836072)
MO
I'd like to know too. Mine failed in the 4420 sprayer. Heartland stocked it and the parts guy knew exactly what I was talking about so it must be a fairly common problem.
Adrian
Posted 6/26/2018 21:15 (#6836172 - in reply to #6836112)
South Georgia
Fingers77 - 6/26/2018 20:59
Thanks, but that's not really a whole lot cheaper than through Deere or Case. Surely it ought to be available for $25 somewhere I'd think.
Thanks,
Adrian
Adrian
Posted 6/26/2018 21:17 (#6836180 - in reply to #6836126)
South Georgia
NMO Redpower - 6/26/2018 21:02
I don't think there's any argument about it bring a common problem, no matter which color machine you're talking about. Every time I've ever needed one, it was in stock, which I think says it all.
Adrian
LJKCK
Posted 6/26/2018 22:59 (#6836415 - in reply to #6836072)
Western ND
i put one like this in dads 3310 after the factory one broke. I had one out of another seat base lying around and seen that there was a provision for it in the sprayer base so a little rerouting of some wires and an air line we were back in business. The hardest part was finding a fitting for the air line.
(switch (full).jpg)
Attachments switch (full).jpg (14KB - 77 downloads)
redblooded
Posted 6/26/2018 23:11 (#6836428 - in reply to #6836072)
Shelburne Ontario Canada
Hose is plumbed too tight out back of arm rest. Hose should be clamped firm in armrest after switch install but its not..... i have used super glue on install that goes along time.
MX255
Posted 6/27/2018 06:05 (#6836567 - in reply to #6836428)
southwest Missouri
Search the Sears Number on it,, it can be had off interent for around $37,, not the $65 robbery case IH wants
Adrian
Posted 6/27/2018 06:42 (#6836611 - in reply to #6836415)
South Georgia
LJKCK - 6/26/2018 22:59
I was looking for something along those lines, but all the ones I found were only air valves without the electrical switch part built in. What would you call that switch?
Adrian
Adrian
Posted 6/27/2018 06:44 (#6836617 - in reply to #6836567)
South Georgia
MX255 - 6/27/2018 06:05
I'll admit that I didn't look for a long time, but I did look for a few minutes. All the prices I found for the Sears number were around $47-48. If I can find that part for $37, I'll get one to keep on hand.
Thanks
Adrian
F_armer
Posted 6/27/2018 09:00 (#6836905 - in reply to #6836617)
WC Saskatchewan
http://www.tractorseats.com/p-3187-km-1300-air-switch.aspx
I was going to order one from these guys, but shipping alone was going to be 65 bucks to canada
LJKCK
Posted 6/27/2018 13:36 (#6837366 - in reply to #6836611)
Western ND
Adrian
I just googled air seat switch to get the picture, I know some aftermarket tractor seats use them and a lot of Caterpillar equipment does too. I think you can find them for about the same $ as the OEM piece of plastic junk.
EDIT, just found this after seeing the above link.
http://www.tractorseats.com/p-837-km-1000100312001201-air-switch-ki...
Edited by LJKCK 6/27/2018 13:39
