AgTalk Home | ||
Forums List -> AgTalk Cafe | Message format |
countryflunky![]() |
sc ks | Looking for insulated water jug that is sealed that I can carry in tractor, pickup, four-wheeler that can tip n all that won't leak plus keep water cold. TIA | ||
PRNDL![]() |
Texas & western Iowa | Not sure if this is quite what you have in mind, but works well in the heat of Tx. https://www.amazon.com/CamelBak-Podium-Insulated-Water-Bottle/dp/B00... | ||
sc ks | That would be great but would like more capacity | ||
justbad7![]() |
Northwest kansas | This jug has easily been the best thing I have purchased recently. WILL NOT LEAK. Also, actually insulation. The jug is quite large because of the 1" insulation around the entire thing. Only thing with this jug is you need a bottle to drink out of. | ||
Abomb![]() |
I’ve got one of these, maybe not as big as you want but don’t leak and the spout stays clean since it’s under the cap. https://www.cabelas.com/product/VACUUM-H-BOTTLE-OZ/2463303.uts?produ... | |||
NWNODAK![]() |
NWND | This Under Armour jug doesn't leak and works pretty good. Gotta fill with ice if you want it cold all day tho. (20180517_144031 (full).jpg) Attachments ---------------- ![]() | ||
flatlander2010![]() |
Pricey but the yetis. I have an rtic 1/2 gal that works good but is tippy in the semi | |||
jd4930![]() |
Central ND | Wife and girls got me a 1 gallon yeti for early father's day present. AWESOME, I absolutely love it, it's heavy but it's stable, no leaks and COLD. Don't put too much ice in or you will run out of water because it does not melt during the day Edited by jd4930 5/17/2018 17:51 | ||
Red Paint![]() |
SW “Ohia” | countryflunky, Not insulated, but I still haven't found anything that beats an old fashioned milk jug. Handle is great, they're stable, and they hang perfectly on a 3-point arm crank. Price is right too. Edited by Red Paint 5/17/2018 15:27 | ||
Millhouse![]() |
South-central Nebraska | Got the 1 gal Yeti for my Birthday. Only problem ive had is I must put it in a plastic bucket so when it bangs against the tractor glass it doesn't break the glass. | ||
1070![]() |
south west in | Gott tip@tap | ||
Beethauler![]() |
Michigan's Thumb | NWNODAK - 5/17/2018 15:41 This Under Armour jug doesn't leak and works pretty good. Gotta fill with ice if you want it cold all day tho. I have the same one and fill it full of ice but keeps it cold all day, it's the best one I have had in a while. | ||
jd8850![]() |
Roseglen, North Dakota | Are you able to get your seed in the moisture? Meant for NW NoDak Edited by jd8850 5/17/2018 16:27 | ||
NWNODAK![]() |
NWND | jd8850 - 5/17/2018 15:26 Are you able to get your seed in the moisture? Meant for NW NoDak Marginal at best and getting worse each day! Thought I had my soys in great moisture. Spent lot of time checking. Came back 5 days of wind later and half are sprouting others laying in dry. Fun stuff. No rain yet. They say tonite maybe. Won't believe it until it happens. Only forecasting a qrtr inch or so tho. Oh well better than we are today Edited by NWNODAK 5/17/2018 17:00 | ||
jd8850![]() |
Roseglen, North Dakota | Yes it seems like Western 1/3 of ND is getting punished for some reason :(. 90% chance today and only wind. Don't think we will even plant beans unless it rains | ||
blacklander![]() |
Central Texas | Also got a 1 gallon Yeti for a birthday present. Been using it lately in 90 degree Texas heat and it holds ice a couple days. Doesn't tip over and is easy to drink out of with no dribbling down your shirt. Best jug I've had. | ||
sand85![]() |
C IL | I have a small soft-sided cooler that holds 8 water bottles. Stable, does not tip, liquid of your choice in each bottle, I just put bottles back in them upside down when empty. I was actually getting ready to ask on here about small 12V coolers and then the water is always guaranteed cold in the cab. I also have a big thermos to keep cold things really cold. | ||
htfsc![]() |
NC | https://www.rticcoolers.com/shop/drinkware/One-Gallon-Jug-Stainless Same as a yeti and almost $100 cheaper. Fill it every morning and put a little ice in it and it stays cold all day even when it's over 90° | ||
farmer48![]() |
EC Kansas | I just got a rtic half gallon jug this spring. I can fill it one morning and still have ice the next morning after sitting in the truck. The bad thing is it tips over pretty easily but the lid doesn't leak. I have a 24 oz rtic I refill out of the jug and that fits in the cup holder of the tractor pretty good | ||
Direct Injected![]() |
SW, Missouri | I was given a yeti last year and it's awesome, bought their mount then installed on a board in my tractor (IMG_20180514_170547252 (full).jpg) Attachments ---------------- ![]() | ||
OkieCanuck![]() |
Oklahoma | Yeti Rambler 1 gal. Dont have one myself but heard really good things about them. Only thing is they are $130 though...... https://www.amazon.com/YETI-Rambler-Vacuum-Insulated-Stainless/dp/B0... | ||
NDFARMER95![]() |
ND | Yeti 1 gallon hands down | ||
68milkman![]() |
Monett Missouri | 1/2 gallon RTIC. I built a square box out of 2x4's that keeps it from tipping over. | ||
illinidirtfarmer![]() |
WC IL | The best one is the old 1 gallon round Thermo I had a bout 40 years ago. About 1’ in diameter, didn’t tip over, had a screw on cap that kept the drinking spout clean. I’d give $50 for one if anybody has a good one stashed in the closet. | ||
still learn'n![]() |
SC. KS | illinidirtfarmer - 5/17/2018 22:30 The best one is the old 1 gallon round Thermo I had a bout 40 years ago. About 1’ in diameter, didn’t tip over, had a screw on cap that kept the drinking spout clean. I’d give $50 for one if anybody has a good one stashed in the closet. You talking like this? https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2... | ||
801486![]() |
west central Iowa | https://www.google.com/search?client=ms-android-verizon&ei=9U7-Wp7kM... I've got one like this, 1/3 gallon Coleman if the link doesn't work, it was a freebie from Garst seed corn 20+ years ago. Not enough water for a real long day, but it has never leaked and it's small enough you can usually find a place to put it where it won't fall off. Except once mowing alfalfa on a steep hill it fell off and the rear tractor wheel ran over it enough to shoot it about 20 feet, but it lived through it. | ||
BFarm![]() |
WCIL | They can be had on eBay for much less than $50. I bought a barely used one for about $25 to the door. Bleached it good and mentally returned to the 80's cutting weeds out of beans. Grandpa and dad both had those jugs and now I can drink with my boys. And they never tip over. | ||
Douglass ks![]() |
Douglass Kansas | We use milk jug too, fill it half to 2/3 full of water and freeze it, once frozen solid fill to top with water, and put plastic groceries bags around it. Most of the time I use 4 to 6 bags around the jug, but sometimes I have used as many as fifteen bags at once around the jug, makes a huge difference in how long the ice will last. Sometimes I have to take the plastic bags off to get the ice to melt faster so I can have some water to drink. | ||
WC IL | still learn'n - 5/17/2018 23:05 illinidirtfarmer - 5/17/2018 22:30 The best one is the old 1 gallon round Thermo I had a bout 40 years ago. About 1’ in diameter, didn’t tip over, had a screw on cap that kept the drinking spout clean. I’d give $50 for one if anybody has a good one stashed in the closet. You talking like this? https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2... Similar to that, but mine had a screw on cap on the spout, dirt didn't get on the spout as long as you kept the cap screwed on. I had one like that with the flip thing, and it broke off and was lost, used a whittled stick to plug it for a while. Mine was like the green one above the big ad. | ||
(Delete cookies) | |
