Search Forums | Classifieds (51) | Skins | Language
JD 8235r engine fan
kversh
Posted 2/18/2018 16:54 (#6587410)
Subject: JD 8235r engine fan
I have a 2012 8235r, interim tier 4, 9L engine. I read about guys having problems with the fan set-up and rebuilding or lubricating the fan drive. I am going to start getting ready for spring and while I have it in the shop was going to look at the fan. I can't find anything in the book about lubricating the drive, do I not have on this tractor what the later final tier 4 engines have? What exactly should I be looking for? Tia
9670guy
Posted 2/18/2018 17:05 (#6587426 - in reply to #6587410)
Subject: RE: JD 8235r engine fan
NW IL
https://talk.newagtalk.com/forums/thread-view.asp?tid=615366&mid=514...
I did as described at around 1500 hours.
dfuller
Posted 2/18/2018 17:08 (#6587432 - in reply to #6587410)
Beloit, Ks
When we do it on a 13.5 we have to release pressure on fan drive(valve on back left side of cab). Remove plug right in center of pulley. And use two bolts to threaded into shives to spread apart. It takes a special grease zero to thread into plug that is removes smaller threads inside cavity where plug is removed. Fill with corn head grease. I have a print out I can upload if is the same. If you have a dealer close I would talk to them. There is a spec on belt wear as well.
9670guy
Posted 2/18/2018 17:13 (#6587446 - in reply to #6587432)
NW IL
13.5 is different. I'm guesssing yours is a 9R as our 9030 is different than you describe.
flanders20
Posted 2/18/2018 18:07 (#6587549 - in reply to #6587410)
They have changed and have vents and grease fittings you can leave in most of them now so don’t have to remove plugs and crap. Also using the synthetic grease. Could call your dealer should give you info on updating it.
blue924.9
Posted 2/18/2018 20:18 (#6587965 - in reply to #6587446)
The local dealer told me only synthetic grease now. Even gave a procedure for purging the cornhead grease out
johnypop
Posted 2/18/2018 20:19 (#6587969 - in reply to #6587410)
ND
There are some good You Tube videos that explain and show it real well.
beachfarmer
Posted 2/18/2018 20:20 (#6587971 - in reply to #6587549)
North Central MN
I got that kit for a 13.5 and didn't have a socket small enough to fit in there to put the zerks in where the plugs are now, not sure how that's supposed to work so I just put it back together. Had to put a new one on and that came with vents and the zerks in it.
Poverty Flats
Posted 2/18/2018 20:59 (#6588093 - in reply to #6587969)
SW Minnesota
We have a late model 8000 with 9.1 litre and 9000 with 13.5 litre motor and the fan drives last less than 500 hrs and start leaking oil , they have been greased every 200 hrs. John Deere should have a pip on these fan drives as they cost about $2000 every time.
kversh
Posted 2/19/2018 06:55 (#6588539 - in reply to #6587965)
Thank you for all the responses. I am going to run to the dealer and see if they have any info from Deere they can print out for me. Is there a kit of some kind through parts that has the zerk and vent? Also, are you guys using grease from Deere or getting it somewhere else?
345r
Posted 2/19/2018 08:13 (#6588680 - in reply to #6588093)
Northeast Iowa
https://www.youtube.com/results?search_query=8r+fan+drive
you here and watch video depending on which type of fan you have..3 or 6 bolt
beachfarmer
Posted 2/19/2018 08:13 (#6588681 - in reply to #6588539)
North Central MN
Zerks are 58M5575. At least that's what the bag I have from Deere has written on it, the vent is E14814. Using Deere TY25744 synthetic grease now.
kversh
Posted 2/19/2018 18:00 (#6589811 - in reply to #6588680)
Thanks for the link. That is a great video and answered all the questions I had. Thx again
lferris537
Posted 2/20/2018 06:38 (#6590849 - in reply to #6587410)
West Central Indiana
Hey Kevin,
I just got a service document with P/N's and installation instructions (from Deere) emailed to me from my parts guy for this issue. I can email it to you if you are interested.
Edited by lferris537 2/20/2018 06:39
kversh
Posted 2/20/2018 07:05 (#6590889 - in reply to #6590849)
That would be great! Email is [email protected] Thanks!!
lferris537
Posted 2/20/2018 07:11 (#6590902 - in reply to #6590889)
Email sent
