Search Forums | Classifieds (21) | Skins | Language
How can you tell what size of JIC hyd fittings you have?
77 Farmer
Posted 2/1/2018 18:04 (#6547498)
Subject: How can you tell what size of JIC hyd fittings you have?
Southeastern, IL
Going to order some hyd hose. I don't know how to tell what size the fitting is. I know they do the fittings in numbers. My JIC female end takes a 7/8 wrench. The threads inside are .672. TIA
alkali flats
Posted 2/1/2018 18:08 (#6547506 - in reply to #6547498)
Subject: RE: How can you tell what size of JIC hyd fittings you have?
Eastern Nebraska
THey are the same thread as fine threaded bolt I believe Maybe this chart will help
(jic.jpg)
Attachments (0KB - 398 downloads)
Attachments jic.jpg (59KB - 1207 downloads)
andyn269
Posted 2/1/2018 18:08 (#6547507 - in reply to #6547498)
Lawton, MI
7/8 wrench probably a number 8 or standard size for 1/2" hose
Edited by andyn269 2/1/2018 18:11
(IMG_0135.PNG)
Attachments IMG_0135.PNG (180KB - 1145 downloads)
kirk
Posted 2/1/2018 18:45 (#6547583 - in reply to #6547498)
Dills, FL
https://www.hydraulicsdirect.com/Fitting-Thread-Chart-s/1934.htm
mmaddox
Posted 2/1/2018 18:54 (#6547601 - in reply to #6547583)
Gates has a really nice set of templates for all types of fittings and hoses.
gemarsh
Posted 2/1/2018 18:57 (#6547607 - in reply to #6547498)
Central NE
After working around them for awhile, you'll be able to size them by eye, like a bolt. Use a open end wrench to size and then use the other posters chart.
ETA... slip open end wrench over the male threads, to size.
Edited by gemarsh 2/1/2018 19:01
Gauner
Posted 2/1/2018 19:19 (#6547672 - in reply to #6547498)
if they're not totally corroded you can usually see the number on one of the flats of the female fitting
nwokman
Posted 2/1/2018 20:16 (#6547848 - in reply to #6547672)
Nt
1586
Posted 2/1/2018 20:55 (#6547970 - in reply to #6547498)
If it's on a 3/8 hose it would be an 06-08. On a 1/2 hose it's an 08-08 fitting. Easy way to remember it's in 1/16ths. 08 is 1/2". Deere uses some 05 fittings on fuel lines. 10 or 5/8 is less common. Some on axial flow combines. 06 and 08 jic are the most used and go back and forth on 3/8 or 1/2 hose. Stock both hose size ends.
Angus8335
Posted 2/1/2018 21:07 (#6548001 - in reply to #6547506)
Galena IL
Nice chart
twraska
Posted 2/1/2018 21:20 (#6548037 - in reply to #6547970)
Wallis, TX
1586 - 2/1/2018 20:55
There are jump sizes, using just the hose size will get you the wrong end about 20% of the time.
1586
Posted 2/1/2018 21:38 (#6548081 - in reply to #6548037)
twraska - 2/1/2018 20:20
If you follow my post I'm referring the op original fitting question. He had an 08 size fitting. Unknown whether it's on a 3/8 hose or 1/2. I'm giving him ammo so he knows what size he has.
steve c-il
Posted 2/1/2018 23:06 (#6548254 - in reply to #6547498)
Central Illinois
Use an open end wrench to quickly size the male thread. Wrench size is not always consistent on the swivel nut. There are standard and Heavy gauge swivels that take different size wrenches,
JohnW
Posted 2/2/2018 01:37 (#6548319 - in reply to #6547498)
NW Washington
The tube fitting size number is the number of 1/16" of the tube or fitting. That is a number 4 is 4*1/16 or 4/16 which is 1/4" and so forth, a number 8 is 1/2" a 16 is one inch.
dtracy
Posted 2/2/2018 11:25 (#6549149 - in reply to #6547498)
todd.crow
Posted 2/2/2018 15:22 (#6549677 - in reply to #6547498)
East Central MN
Surplus Center has a really nice chart you can print out that is actual size to compare to the fittings .
http://www.surpluscenter.com/images/techhelp/JIC.pdf
twraska
Posted 2/4/2018 09:05 (#6553242 - in reply to #6548081)
Wallis, TX
1586 - 2/1/2018 21:38
True however,,,, there are 'double jump sizes' and he could have anything from a 1/4" to a 3/4" hose on a -8 fitting.
