Help - Fuel Water Separator on MT765C
Max the Bavarian
Posted 1/11/2018 04:18 (#6495547)
Subject: Help - Fuel Water Separator on MT765C
Can anyone tell me original Cat number for the fuel/water separator on the Challenger MT 765 C ?
Just ordered a filterset for C9 engines , and the waterseparator that came looks different - at least a lot bigger ( # 326-1643)
Problem is that the last filter used was a white agco filter so i can“t check the number anymore.
The fuelfilter is 1R 0762
Thanks in advanve
Max the Bavarian
MN Dean
Posted 1/11/2018 07:30 (#6495735 - in reply to #6495547)
Subject: RE: Help - Fuel Water Separator on MT765C
The separator has changed. New ones don't use the plastic bowl anymore. Not near the tractor or I'd send you a pic.
Breeggy
Posted 1/11/2018 07:36 (#6495747 - in reply to #6495547)
326-1644
a 326-1643 will work in its place if you have room, same filter just longer ( meant for the big blocks)
