AgTalk Home | ||
Used New Holland 195 manure spreaders. Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forums List -> Stock Talk | Message format |
w'burg |
Marengo, Ia. | I've got a couple used New Holland 195 manure spreaders in my price range(cheap) that I'm going to look at. | ||
1 row |
Columbia co. Wi | The return track underneath for the apron rotted out pretty fast on mine and caused apron breakage and sprocket jumping. If the wheels stand straight up, the tandems haevn't cracked yet, but they will. I fixed and fixed and ran mine until it was completely used up. hooked it to the pickup with blocks and jack and tools and spare tire and pulled it to consignment auction (surprised I made it!) and it brought $1500, $1400 too much. Like thr H&S much better. | ||
Brian sepa |
Lancaster County, Pa. | When I was looking at used 195's I found quite a few that had the top cover on the beater gearbox rusted thru from manure laying on it. Take your adjustable wrench along so you can pull the check plug and see if water runs out. Also crawl underneath and check the cross members, especially toward the rear. | ||
ak47 |
The desert of south central neb | Hope you have better luck finding a good one than we did. We just went and bought a new Meyers and was done with it. All the ones we looked at were rusted through junk. | ||
Flamme Farms |
Central iowa | Yep thats what happend to ours i wash and oil ours once a year bought ours brand new paint basically washed right off good spreader havnt done anthing but tighten the apron tell this spring when dad dropped it off the concrete and wrecked a tandem $3500 for a new one ouch | ||
w'burg |
Marengo, Ia. | I wish I could afford new.... I'll just make due with someone else's junk. I can't keep borrowing spreaders. Thanks for all the tips everyone! | ||
garvo |
western iowa,by Denison | we had good luck with knight 1040 and the older model 410-seems like there was better places to weld which the old 410 was a good learning welding teacher the 195 was much harder to patch and weld | ||
Abomb |
Some guys must be doing a ton of loads or hard as hell on them? Ours done atleast 1500 loads probably 2000 piled until it runs over every corner and so far it's just been greased a lot, web adjusted, and one link taken out of the web. Edited by Abomb 12/2/2017 07:41 | |||
w'burg |
Marengo, Ia. | Not cleaned up and sat outside is the death of most manure spreaders I've looked at.... | ||
(Delete cookies) | |
