Search Forums | Classifieds (7) | Skins | Language
JD 9330 or CaseIH Steiger 385
RockyMtn
Posted 11/20/2017 09:31 (#6377436)
Subject: JD 9330 or CaseIH Steiger 385
North East Colorado
I'm thinking of upgrading to a four wheel drive over my current MFWD. Which tractor is prefered and reasons why. Pros and cons of each.
dittle07
Posted 11/20/2017 09:47 (#6377459 - in reply to #6377436)
Subject: RE: JD 9330 or CaseIH Steiger 385
Albia, Iowa
Consider dealer support as well into your decision.
centralindianafarmer
Posted 11/20/2017 09:49 (#6377465 - in reply to #6377436)
I own a steiger 385 with 710-70-42 tires. It is a great tractor. Ours has 24xx hrs on it with very little trouble.
RockyMtn
Posted 11/20/2017 10:02 (#6377488 - in reply to #6377459)
North East Colorado
We did just recently lose our local CNH dealer.
chris dds
Posted 11/20/2017 13:59 (#6377881 - in reply to #6377436)
Minnesota
I have a 385 (quadtrac). Unless you have a particular machine in mind, search for a 435, which is the same frame with a little more HP.
Cliff SEIA
Posted 11/20/2017 14:06 (#6377888 - in reply to #6377881)
We bought a 385 last summer, plan on putting a Steinbauer or ekotuning it over the winter to make it a little stronger than a 435.
Posted 11/20/2017 14:09 (#6377890 - in reply to #6377888)
Cliff, we had our 385 ekotuning done. We set went to 450 h.p.
RockyMtn
Posted 11/20/2017 14:10 (#6377892 - in reply to #6377881)
Subject: RE Ivecco engine or Cummins
North East Colorado
Do caseih tractor owners like the Ivecco engine over the Cummins?
mennoboy
Posted 11/20/2017 14:13 (#6377898 - in reply to #6377436)
Rivers, MB
We have a STX 375 quadtrac and a Steiger 435 quadtrac but are all green on the yard other than a 9150 4WD. If you are looking at wheeled tractor, I'd go the JD route. I like the cab and transmission more in the 20 series JD 4Wd's. suspect the 30 series is just as nice if not nicer. I don't like the transmission in our CIH quads. Like the JD autosteer/monitors more as well. And our experience is that JD parts, if needed, are almost always no more than 1-2 days away. Has definitely not been our experience with CNH. Waited up to 5 weeks to get the correct parts for our 375 after some fire damage.
J.L.
Posted 11/20/2017 18:23 (#6378272 - in reply to #6377898)
Iowa
Had a similar experience here. I ordered a wiring harness for the 375 the end of march this year------it showed up at the dealer the middle of august.
Had to wait several weeks for gaskets for the shift control valve I had apart several years ago too.
Well at least it wasn't "no longer available" I guess.
