Pallet jack on ribbed refer trailer floor
west illini
Posted 11/10/2017 15:49 (#6357083)
Subject: Pallet jack on ribbed refer trailer floor
IL
How well does a pallet jack work on the ribbed semi refer trailer floor ?
Hawkeye829
Posted 11/10/2017 15:54 (#6357088 - in reply to #6357083)
Subject: RE: Pallet jack on ribbed refer trailer floor
NC IA
It isn't terrible if you are going dead straight and backwards but it can be a pain if your wheels get stuck in the ribs. it also depends on what type of wheels your pallet jack is using.
west illini
Posted 11/10/2017 15:57 (#6357092 - in reply to #6357088)
IL
FWIW. Prob a cheap jack under a small pallet of chems or a mini bulk tank
Kinda what I was thinking
Birddy
Posted 11/10/2017 16:39 (#6357156 - in reply to #6357092)
ND
You could put plywood down in the area where the totes are.
west illini
Posted 11/10/2017 17:10 (#6357202 - in reply to #6357156)
IL
Thought about that
ECIAfarmer
Posted 11/10/2017 17:31 (#6357233 - in reply to #6357083)
East Central Ia, S. Waterloo
My experience, 20 yrs on Menards receiving dock, did it many times with no problem. Wheels were always wide enough to span the slots. When it's cold those floors can get real slick.
Huib Z
Posted 11/10/2017 18:53 (#6357391 - in reply to #6357083)
Dresden, Ontario
works fine, just need a bit of speed when turning pallet around so the wheels don't get stuck between the ribs.
used to load pallets and totes with onions in the ribbed floor trailers all the time, then got an electric pallet jack.....made the job of loading 52,000 lbs (26skids) a breeze :-)
JChamb
Posted 11/10/2017 19:30 (#6357466 - in reply to #6357233)
Iowa - Floyd County
I'll second that, 12 years working at a grocery store for me. Never had an issue with the jacks but those floors were dangerous with the frozen loads, ended up on my behind quite a few times. I think it would be just fine in a tender trailer.
School Of Hard Knock
Posted 11/10/2017 20:28 (#6357585 - in reply to #6357083)
just a tish NE of central ND
west illini - 11/10/2017 14:49
I can say this....... a full loaded tote of roundup and AMS are quite heavy to move even on the level on a hardwood floor. (lots of weight to control)They are like 265 gallons or there abouts in volume. A full tote of liquid fertilizer si considerably heavier.
Huib Z
Posted 11/11/2017 07:05 (#6358111 - in reply to #6357585)
Dresden, Ontario
2000lbs skids of produce are a b*tch on the old hardwood floors with an old jack with small steel wheels....ha ha I can tell you that from a lot of experience.
the newer ones have larger wheels and are quite a bit easier to move heavy loads
clevepreach
Posted 11/11/2017 11:28 (#6358516 - in reply to #6357083)
Cleveland, MS. Own small farm near Booneville, MS
Used one for 8 years hauling fresh seafood out of Boston. Never had any real problems. As an earlier poster said, just try to have a bit of speed up when you want to go cross ways to the ribs. Also, wet floors are SLICK. Rubber soled shoes help but the floor will still be slick.
Oh yes, did I mention that when the floor gets wet it will be slick? My butt still hurts when I think about it.
1466driver
Posted 11/11/2017 22:11 (#6359522 - in reply to #6358516)
Interstate 35 North ia
I've delivered seed corn with a reefer before , I think its easier to push a big pallet on a reefer floor than a dry van floor provided the floor is dry in the reefer . Like others have said you want to have your speed up when you want to turn on the rib floor .
