Search Forums | Classifieds (149) | Skins | Language
Drain Tile Cost Per Acre?
RetroFarmer
Posted 10/11/2017 09:15 (#6301121)
Subject: Drain Tile Cost Per Acre?
Hi trying to get an 80 acre field tiled this year, but nearly everyone I've talked to in my area is giving me quotes of about $1200 dollars per acre, 4" tile, 30 foot spacing I believe. Does this sound right? I just figured it's high because everyone wants tile after the rain we got this spring.
PTA280
Posted 10/11/2017 09:19 (#6301125 - in reply to #6301121)
Subject: RE: Drain Tile Cost Per Acre?
I’m assuming that includes mains and connections etc.? Where are you located?
RetroFarmer
Posted 10/11/2017 09:22 (#6301132 - in reply to #6301125)
I'm getting quotes of 105-115K for 82 acres tiled with all mains factored into that. I am located in Southeastern Indiana.
9670guy
Posted 10/11/2017 09:25 (#6301141 - in reply to #6301132)
NW IL
Do you know what size mains they are using and how many feet of main
RetroFarmer
Posted 10/11/2017 09:26 (#6301143 - in reply to #6301141)
I wrote that down somewhere, but I think it's one 12 inch main.
paul the original
Posted 10/11/2017 09:32 (#6301154 - in reply to #6301143)
southern MN
Been around $700-800 an acre to go with 80 foot spacing here. Random mains added to exsisting mains included. That spacing works for us pretty good.
Paul
RetroFarmer
Posted 10/11/2017 09:36 (#6301160 - in reply to #6301154)
Ok so sounds like these numbers aren't that unreasonable then.
chevydiesel07
Posted 10/11/2017 09:50 (#6301193 - in reply to #6301160)
East Central Indiana
We are a drainage company in eastern Indiana, my email is in my profile if we can help in any way.
Edited by chevydiesel07 10/11/2017 09:52
AGB
Posted 10/11/2017 10:16 (#6301242 - in reply to #6301121)
Mid-Michigan
There are a lot of factors the affect the cost. Main size and hookups being two big ones. Around me ( we are very flat) 800 would be on the low side. 1200 would be on the high side but I don't know how your field lies. Don't try to cut corners on this job.
RetroFarmer
Posted 10/11/2017 10:26 (#6301255 - in reply to #6301242)
It's a dead flat swamp. I bought the land for what I consider "cheap" because it's never been tiled, and at least a half dozen farmers who have farmed it over the years told me on a good year you'll be planting at the end of may at the earliest, it's just so wet. This year's rains spun that into July. It's truly a beautiful farm, not too many farms around here where you can gaze across a flat field a mile long, but it's deadpan flat, when I was out there this spring the whole field had a 1/2 inch layer of water over it, despite it being a highpoint in the county. I won't be cheaping out on this one, but I obviously don't want to get taken for a ride either.
AGB
Posted 10/11/2017 10:31 (#6301264 - in reply to #6301255)
Mid-Michigan
RetroFarmer - 10/11/2017 10:26
If you have a good outlet and a good contractor, you aren't going to believe what a 30 ft tile job is going to do for you.
Scammer#1
Posted 10/11/2017 10:31 (#6301265 - in reply to #6301255)
West Michigan
What about buying your own plow and doing it yourself? Maybe even rent a tractor from a neighbor and then he could rent your plow or could trade too?
Once you buy a plow you will tile everything you own.
Indiana Smith
Posted 10/11/2017 11:05 (#6301319 - in reply to #6301121)
I just finished tiling 40 acres on 40 foot centers. I have my own tile plow. Cost was roughly $500 per acre. Most days we had three guys working at it and it took about two weeks. But we had five Outlets to deal with and a lot of short runs so it took a little longer than a than a straight one Outlet field would.
ltct04
Posted 10/11/2017 11:21 (#6301335 - in reply to #6301255)
east central iowa
Being a mile long where will the main be located? How much depth do you have at outlet? Just curious what kind of grade you can get on tile and how long the lateral runs can be?
Farms With CASE
Posted 10/11/2017 11:33 (#6301359 - in reply to #6301121)
North Liberty and South Bend, Indiana
Seems awful reasonable for that spacing and mains.
GrainTrader
Posted 10/11/2017 12:09 (#6301428 - in reply to #6301121)
20 Miles West of Indianapolis Indiana
IMO you will be so happy after a couple years of having it ruled on your scenario you really won't care what it cost.
Heavy wet farms that get tiled as well as you are discussing turn out to be awesome !
Blusteryknollfarm
Posted 10/11/2017 12:25 (#6301453 - in reply to #6301121)
North Central Illinois
I had a few miles of 4" laterals plowed in for a 92¢/ft this summer. 12" main cost $6.50/ft.
olivetroad
Posted 10/11/2017 15:28 (#6301706 - in reply to #6301121)
Kingdom of Callaway - Fulton, Mo 65251
Could you buy a plow and a mini-hoe and do it yourself?
Bornfarming
Posted 10/11/2017 19:37 (#6302134 - in reply to #6301121)
NE IN
You should be able to figure the cost of material by itself. Then you'll know what they are charging for labor to install. 1000k for 35' spacing is plenty. I would make sure they use good tile, GPS all lateral runs and plow it in. Since your in Indiana and not Iowa, make sure they don't put your lateral lines all in at 40"deep or deeper. Best investment you'll ever make, unless the crew are the "hurry up and Gitr done" type.
Istumped
Posted 10/11/2017 20:57 (#6302422 - in reply to #6302134)
ne il
Yes commercial guys are that expensive. Depending on the situation. You could have them do the mains then you could do the lateral. If you had your own plow. Seriously think about buying your own plow.
TCF9120
Posted 10/11/2017 21:00 (#6302429 - in reply to #6301121)
Sun Prairie, WI
In our area $1200.00/acre for 30'spacing would be cheap. We tile and average costs for 30' is right around 14-1500.00/acre depending on main size and distance. I have a very high optioned pull type gold digger for sale if you want to try this on your own. Up here it is getting late to find a contractor who is not booked up for fall/winter.
Good luck with the project, like others have said 30'spacing and a good contractor will turn that farm into something very productive
ontario
Posted 10/12/2017 09:29 (#6303302 - in reply to #6302429)
I’ve been 1200-1400/ac here . 20-22 ft spacing to mains. Includes pipe connections and outlets.
gpsdude
Posted 10/12/2017 11:54 (#6303542 - in reply to #6303302)
NE South Dakota Clark, SD
Just doing some rough figuring here. 4" tile 1452 ft/acre at .30= $435.60 plus install at .45= $653.40. Then add main cost and I think you are in the right ballpark. If they are long runs, I think you could find someone under .45 a foot for install.
PatrickM
Posted 10/12/2017 14:55 (#6303794 - in reply to #6301121)
It depends. We recently tiled a 60 for a customer, pock-marked with drown out spots, with (1) 12" main, (2) 8" mains, and a 6" main. 4" on 50' spacing, silty clay loam, 36-42" deep, .1% slope, all installed with a wheel trencher. $60,000. The customer wished he would have made the investment sooner. The farm went from his biggest aggravation, bottom loser to something that he enjoys farming.
I just bid a job. 485 acres continuous. Multiple mains from 24"-10". Sandy clay loam with abundant iron oxides , 4" muck nit tile at 50'. Three major utilities to cross, existing pivots with water and electric, major diked county ditch with permit and design considerations. A lot of excavator work with cave-in safety precautions (6' to 16' deep on the major 24" main). Proposed seed corn production. $1500/ac. NW Indiana.
PatrickM
Posted 10/12/2017 15:09 (#6303810 - in reply to #6301154)
I find it somewhat surprising, because I follow your drainage posts, but your soil drainage problems seem very similar to our's locally. Do you farm any muck soils? Our biggest problem is tiling muck soils. The tile works for a limited number of years before iron ochre plugs them. We started to recently install clean-outs in the field.
