AgTalk Home | ||
New Holland T4 Tractors Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
UKag |
Central KY | What's everyone's experience with the New Holland T4 tractors? Looking at a T4.110 or a T4.120- really trying to find one with a dual command transmission. Do they seem to be holding up well? Any common issues? Any issues with the DEF? Will be used for loader work and primarily a hay tractor- pulling a 10' discbine, raking, pulling a round baler and a square baler- also bushhogging, spreading fertlize and as a backup to pull a 6/11 planter if needed occasionally. TIA | ||
codydfarms |
Should work perfect for everything you described, they run pretty strong | |||
genesis |
England | no def on a t4 | ||
olivetroad |
Kingdom of Callaway - Fulton, Mo 65251 | We have a 3 or 4 year old T4.95. It doesn't use DEF. We really like it, its very handy for feeding and smaller jobs. It struggles on a big baler, mainly from frame size and braking weight on hills. Perfect size for a square baler and raking. Ours is a shuttle shift with 12 gears. I wish it was a dual command or whatever they call it with a rabbit/turtle high-low button in each gear. | ||
dsfarms3585 |
NY | My 16 t4.100 has DEF. no issues so far | ||
UKag |
Central KY | Thanks for the responses. I think the "0" series T4's have DEF, the first generation "5" series did not. Guess it's coming, might as well get used to it, so that's not really a big deal to me. This tractors replacing a TL90A, and according to tractordata, the T4's slightly heavier, so it won't be any worse than what I'm used to anyway. Thanks for the suggestions David, I'll be sure to keep them in mind. Wasn't even dreaming of a brand new tractor, but NH has some smoking deals on closeout models right now, and you can't afford to buy late model used when you compare to new... | ||
(Delete cookies) | |
