Search Forums | Classifieds (166) | Skins | Language
How to remove side panel on a JD 7210
Kenny
Posted 9/14/2017 18:25 (#6248095)
Subject: How to remove side panel on a JD 7210
EC IA
My son called me, tonight, & wants me to see if I can put a new
fan belt on his 7210 tomorrow while he is at work. I went over
& took a look at it but I can't figure out how to get the side
panels off. Can't find the book & it has a loader on it to make
things more interesting. Sure would appreciate a little help.
Will get a belt in the morning.
LLC
Posted 9/14/2017 18:30 (#6248103 - in reply to #6248095)
Subject: RE: How to remove side panel on a JD 7210
NW Illinois
Pop hood up,take off front side grill,loosen nuts on front,slide forward and remove
danaoh
Posted 9/14/2017 18:45 (#6248123 - in reply to #6248103)
xenia ohio
Fun part for me is finding the release handle for the hood. It's on the right side.
Kenny
Posted 9/14/2017 19:33 (#6248227 - in reply to #6248123)
EC IA
Thanks guys !
JRthefarmer
Posted 9/14/2017 20:48 (#6248424 - in reply to #6248095)
SESD
Don't know if it the same or not. On my 7610 you pull them down a little and pop the top out, then lift them up and out. Same for the big engine panels and the small ones beside the radiator. There is a little spring deal that holds them up and keeps the tabs on the top of the panels engaged.
WildBuckwheat
Posted 1/8/2024 21:21 (#10564200 - in reply to #6248095)
Middlesex County, Ontario
On the right side of the engine is a black handle, pointing downwards, that you pivot forward to unlatch the hood.
Lift up the hood. Above the front little side panels are small black tabs pointing up that pivot forward to unlatch the little side panels up by the rad. Remove those little side panels.
Now you’ll see where you can use a 1/2” or 13mm socket to undo the large engine side panels.
