Search Forums | Classifieds (61) | Skins | Language
Case In-line square baler
Saskyfarmer
Posted 8/26/2017 09:13 (#6210899)
Subject: Case In-line square baler
East Central Saskatchewan
When and why did they stop building them? Are they any good, or did they go back to a traditional style because they had so many complaints and where terrible? Looking at one from a dealer right now, and on the look for one privately if I can find a good one. Just wanted to ask the NAT community before I express any interest. I'm looking at this to be my secondary small square baler to back up/help my 348 (which yes, is broke down again, twine knife and wiper plate broke). Thanks.
brudno
Posted 8/26/2017 09:23 (#6210918 - in reply to #6210899)
Subject: RE: Case In-line square baler
SC WI
I thought they were just re-badged Hesstons.
slimdairylate
Posted 8/26/2017 09:23 (#6210919 - in reply to #6210899)
In 2000, I was running a 327 & 348 Deere balers. I ordered a 8545 with belt thrower brand new. I liked the wide pickup and crop flow, but the plunger shear bolt sheared way more often then on my deeres. On the thrower end, with the bottom cut, resulted in a wagon 6-10 inches deep in loose hay that fell to the ground on my Deere balers with side cut. Ended up walking thru deep material unloading kicker racks and had all that loose material to deal with after. The bottom cut didn't hand stack like I wanted and the machine went back to Case IH after one season. It could eat the hay but the pairing with bale racks ultimately was a deal breaker for me.
Omar
Posted 8/26/2017 09:32 (#6210938 - in reply to #6210918)
Elmira, Ontario
brudno - 8/26/2017 10:23 I thought they were just re-badged Hesstons.
At the time, CIH owned half the plant, so you could make an argument in the other direction too. Without their money, it's doubtful the plant would have stayed alive.
The reason for going to the side-pull style is the CIH/NH merger. To be allowed to happen, CIH had to sell their share of the Hesston plant (called HFI for Hay Forage Industries). The balers offered now would be from the New Holland plant.
Saskyfarmer
Posted 8/26/2017 09:34 (#6210942 - in reply to #6210919)
So it wastes a lot of hay? I am looking to make bales to pick with a stackliner, so would it be ok for that? I don't like to see lots of wasted hay so that could be a deal breaker for me. Are the bales of uniform quality and length? That's also very important too.
Saskyfarmer
Posted 8/26/2017 09:42 (#6210949 - in reply to #6210938)
Omar - 8/26/2017 09:32
So new Case balers are just NH's with red paint and Case decals? That's what I thought:)
brudno
Posted 8/26/2017 09:48 (#6210960 - in reply to #6210938)
SC WI
Learn something new everyday thanks
KevinBfromIllinois
Posted 8/26/2017 09:50 (#6210965 - in reply to #6210949)
RINGWOOD, IL
Yes thats all they were was rebadged IH's, case has not built a baler since the early 60's.
tater1086
Posted 8/26/2017 09:57 (#6210975 - in reply to #6210942)
Snipesville, GA
We have two inline balers and really like them. I think the bottom cut helps bales tie together on top and bottom and haul better.
slimdairylate
Posted 8/26/2017 10:29 (#6211036 - in reply to #6210975)
I'm not saying that they waste hay. There will always be loose chaff from each flake cut. With the side cuts you don't see it as it drops to the ground. I liked the baker, just didn't need the chaff in the wagon. Dropping bales on th ground would be fine
Saskyfarmer
Posted 8/26/2017 10:44 (#6211062 - in reply to #6211036)
Ok. But you would still rather have a JD over a Case In-line I'm assuming?
Survivor
Posted 8/26/2017 12:09 (#6211196 - in reply to #6211062)
Moreauville LA
Neighbor had one, sure looked like the tool truck stayed beside the baler plenty.
Galaxie64
Posted 8/26/2017 12:29 (#6211228 - in reply to #6210899)
WY, OK
Get an inline.  If a Case model you can get parts from a Hesston dealer.  They have less parts, harder to plug easier to bale with and faster.  Our Hesston was new in about '92 and used it until sold this year.  Fantastic baler.  I'd never go back to an offset.
drunde
Posted 8/26/2017 14:09 (#6211377 - in reply to #6210899)
sw wisconsin
We have an inline Heston, best small baler we have ever had.
twraska
Posted 8/26/2017 14:53 (#6211450 - in reply to #6210899)
Wallis, TX
We've ran the Case inline, Case (NH style) and a JD348.  The inline was a good baler, but it had one 'problem' in that in would choke up and pop a shear bolt on a way too often.  If it even thought it saw a clump it would choke the stuffer.
The 348 wouldn't make a straight bale no matter what you did.  Constantly had to adjust the stuffer arm or we got banana bales.
The NH style is the most forgiving on windrow size and keeps a generally good bale with minimal effort.
Edited by twraska 8/26/2017 15:03
slimdairylate
Posted 8/26/2017 16:08 (#6211555 - in reply to #6211450)
Thank you for confirming my memory of many shear bolts popping!
2greentractors
Posted 8/26/2017 19:13 (#6211807 - in reply to #6210899)
Go find a Freeman. New or used, they are the best hands down!
http://www.alliedsystems.com/freeman/
tater1086
Posted 8/27/2017 20:24 (#6213883 - in reply to #6211807)
Snipesville, GA
We have a 7110 Magnum on ours and love it with the powershift. We keep it full and don't play with it. We bale Bermuda grass only in our area.
