Search Forums | Classifieds (89) | Skins | Language
what is a good square baler twine?
gene_champ
Posted 7/18/2017 20:07 (#6134638)
Subject: what is a good square baler twine?
NC Iowa
i know it is not Jaguar from mills fleet farm. now i know it is not this from tractor supply. years ago, used to get holland extra from the local coop. maybe they still have it. what ever it costs, if it good, it is worth it. nothing worse that having twine trouble when it is 90 degrees and clouding up.
pic shows how frizzed up it is. i think that it breaks when makes a knot in these spots. if i was brave, i would try plastic. i think i have to make bill hook adjustments to use it, and not sure what to do.
Edited by gene_champ 7/18/2017 20:08
(20170718_153215.jpg)
(20170718_153255.jpg)
Attachments 20170718_153215.jpg (102KB - 446 downloads)
Attachments 20170718_153255.jpg (139KB - 423 downloads)
MoeSzyslak
Posted 7/18/2017 20:12 (#6134658 - in reply to #6134638)
Subject: RE: what is a good square baler twine?
Small square? i always preferred to get clover brand
Badger
Posted 7/18/2017 20:32 (#6134719 - in reply to #6134638)
Huntley Montana
UNLESS you have sheep, GO PLASTIC 170 knot 7200 or 9600. Couple ajustments & you will NEVER look at sisil  again. Bridon, Exxon  both good
WCGrad
Posted 7/18/2017 20:36 (#6134734 - in reply to #6134638)
WC Ohio
Sisal seems to be having quality problems the last few years. I believe most of it is made in just a couple of factories and gets different names on the paper.
9600-170 plastic is what we used for years with a JD 336. 9000 seemed to have more busted bales.
dmax2001
Posted 7/18/2017 20:38 (#6134736 - in reply to #6134719)
Lawton MI
Agree with using plastic, we've had great luck with New Holland brand in NH baler.
jcwag
Posted 7/18/2017 20:41 (#6134750 - in reply to #6134638)
Upstate Ny
We went plastic 3 or 4 years ago.. much fewer problems. I would imagine there is not much difference in brands....we are using balecord.
Edited by jcwag 7/18/2017 20:49
cjd12000
Posted 7/18/2017 20:46 (#6134762 - in reply to #6134750)
candor ny
Same here 9k sisal is hit or miss 7200 is pricey and plastic is strong and cheap. Only problem we had switching was had to tighten draw tension from twine box.
Edited by cjd12000 7/18/2017 20:47
JellyJugz
Posted 7/18/2017 20:47 (#6134765 - in reply to #6134750)
NC South Dakota
Plastic is the ONLY option for squares
Direct Injected
Posted 7/18/2017 21:12 (#6134824 - in reply to #6134765)
SW, Missouri
Plastic and don't look back
Saskyfarmer
Posted 7/18/2017 21:27 (#6134885 - in reply to #6134719)
East Central Saskatchewan
Why do you have problems with plastic when you have sheep? I have used plastic for a long time and have never had any problems.
cih1660
Posted 7/18/2017 21:29 (#6134891 - in reply to #6134638)
WI
Another vote for plastic if your knotters will work with it. I've tried everything under the sun for sisal twine. Actually, I have great luck with Jaguar 9,000 plastic, which is surprising because their sisal twine is crap.
Good luck, there's nothing more frustrating than trying to beat the rain with junk twine.
Especially this year.
Two Hawk
Posted 7/18/2017 21:37 (#6134925 - in reply to #6134885)
Southern Nevada desert
Saskyfarmer - 7/18/2017 07:27
I was told that they dock the wool price for poly tails in the wool.
Bridon poly here.
hillfarmer
Posted 7/18/2017 21:51 (#6134983 - in reply to #6134891)
Bridon Cartage 7200 70 # bales 38 inch long
Saskyfarmer
Posted 7/18/2017 21:58 (#6135004 - in reply to #6134638)
Go with plastic, have very few troubles with it. I use Balecord in blue, (9000 feet rolls I believe), I hate orange now since I know blue is so much easier to see and work with when stacked.
Edited by Saskyfarmer 7/18/2017 23:30
Saskyfarmer
Posted 7/18/2017 22:02 (#6135016 - in reply to #6134925)
Oh, I didn't know that. I usually clean up the tails before I feed, and the ewes are outside on pasture so they don't get affected, but I will have to watch for that now. Agree, same as Sheep Herder.
Edited by Saskyfarmer 7/19/2017 10:24
paul the original
Posted 7/18/2017 22:05 (#6135021 - in reply to #6134824)
southern MN
Hardly ever see small squares with plastic around here, just isn't done.
Paul
Bubbaspb
Posted 7/18/2017 22:14 (#6135054 - in reply to #6134638)
Western WI
I vote plastic. 328 jd with kicker
Blusteryknollfarm
Posted 7/18/2017 23:06 (#6135164 - in reply to #6135021)
North Central Illinois
I can't get plastic to work with the belt type thrower on my baler. Works most of the time, but when you get to a thin spot in the swath and the bale sits at the base of the thrower for too long and it melts right through it. Also, I find enough plastic twine wrapped on rotary hoe bearings that I don't want to add more to the collection. It seems like even if you try your best to be tidy and throw it all away, there's always something that gets in the wrong place.
m3farmer
Posted 7/18/2017 23:23 (#6135193 - in reply to #6135021)
SW Minnesota, Lyon County
I'm late to the party for this thread, but really Paul? I've got a 24T that plastic is the only thing that makes it happy. Had an Oliver before that and ran plastic through that like no tomorrow. The sisel (sp) we get around here , not far from you Paul, is anywhere from pencil lead to quarter inch in size. Just doesn't work for us as far as baling. I'm not the end user so after it's in the barn, it isn't my problem. This is my experience for what it's worth.
School Of Hard Knock
Posted 7/19/2017 00:58 (#6135252 - in reply to #6134638)
just a tish NE of central ND
Are you sure that is 9000 twine? Looks so thin.......
Seems all sisal twine sint what it used to be.
Fawazhay
Posted 7/19/2017 01:12 (#6135255 - in reply to #6135252)
Northern CA
I sell a couple truckloads of twine a year plus use about 12 pallets myself. I have had excellent results with Cordex, Poly Excel and IFS. I am sure you can find a dealer for one of those near you.
I had a lot of quality control problems with Bridon one year. I was very disappointed in how the company didn't stand behind their product.
nyjim
Posted 7/19/2017 04:12 (#6135286 - in reply to #6134638)
100 miles north of the NYC crapper
No such thing as good sisal twine any more
RickB
Posted 7/19/2017 04:36 (#6135289 - in reply to #6134638)
Lincoln County. NC
2 years decent results selling Holland Extra bought through New Holland via Briden. This year it has New Holland wrappers. Not one complaint AFTER the sticker shock. My customers have largely switched to Tyrite Blue 9600/170 plastic in the last 3 years.
jd43
Posted 7/19/2017 05:02 (#6135297 - in reply to #6135289)
Northeastern Pa.
Clover has worked good for me. TSC had a brand that I never had an issue with but they switched suppliers now so I don't know. I bought the last of their old stock at the local store.
Posted 7/19/2017 06:19 (#6135358 - in reply to #6134719)
Plastic Orangeline 7200 170# knot strength.
http://www.runnings.com/farm-haying-and-baling-equipment/orangeline-plastic-baler-twine-7200-ft-170-lb.htm
If you can get your baler to run it it's consistent and tough stuff. Natural twine is just too inconsistent anymore.
German Shepherd
Posted 7/19/2017 06:59 (#6135439 - in reply to #6134638)
170 plastic twine.   I don't even consider anything else.
German Shepherd
Posted 7/19/2017 07:01 (#6135447 - in reply to #6134925)
We've used plastic for 10 years and never, ever had a dock on the wool.   I've never seen plastic twine fragments in the wool for that matter.    Just put up 400 square alfalfa bales with plastic last week and they are all going to the sheep.
NAQ
Posted 7/19/2017 07:28 (#6135503 - in reply to #6134638)
Mt.Gilead Ohio
We use 9600/210 it's bigger diameter for Knott strength. You can really make a bale plus the thicker plastic is easier on your hands
FarmOR
Posted 7/19/2017 07:37 (#6135509 - in reply to #6135439)
Eastern Oregon
Most of you using the 170 tensile must be making 50# bales?
Around here, 100# bales are the norm and 210# plastic twine...
MiradaAcres
Posted 7/19/2017 08:57 (#6135656 - in reply to #6134638)
scmn
I prefer Brazillian Green that Runnings carries. Also available in gold, but seem to have more trouble with the gold.
gene_champ
Posted 7/19/2017 09:13 (#6135679 - in reply to #6135656)
NC Iowa
I used to get twine call green cow. Was happy with it. Always had good luck with tractor supply until this time.
Jaguar was inconsistent thickness, ranging from .25 to binder size.
My experience is twine quality has down as much as price has gone up.
Thanks for all replies. I need to serious consider plastic. Don't have much hay anymore, but when I go out to bale, I want to bale.
Two Hawk
Posted 7/20/2017 23:17 (#6139444 - in reply to #6135447)
Sheep Herder - 7/18/2017 17:01
Maybe I was fed a line of BS, the conversation was with a sheep man who grazes my fields in the winter. He claimed that the sheep wool picked up the 1" cut tails that the knotters leave behind when the sheep bedded down in the alfalfa fields.
He runs a thousand head or so, I just assumed he knew what he was talking about, I should know better by now...........
Fawazhay
Posted 7/21/2017 18:15 (#6140752 - in reply to #6139444)
Northern CA
I think grazing the fields is different than feeding sheep hay with plastic twine. I wouldn't discount the issue.
