Search Forums | Classifieds (53) | Skins | Language
John Deere 4450 water temp gauge problem
JohnDeere8650
Posted 7/4/2017 11:39 (#6105079)
Subject: John Deere 4450 water temp gauge problem
I have a 1983 4450. Have been having intermediate water temp gauge problems. Sometimes the gauge will stay in the cold position and never move, other times it will work for a while and then return to cold. All of the other gauges function as should.
I have replaced the water temperature sensor already. Wires under hood seem to be fine. Was wondering or hoping that someone else has experienced this before and knows what's going on... thanks ahead of time!
(IMG_0678.JPG)
Attachments IMG_0678.JPG (118KB - 229 downloads)
School Of Hard Knock
Posted 7/4/2017 12:20 (#6105148 - in reply to #6105079)
Subject: RE: John Deere 4450 water temp gauge problem
Central ND
I guess Im no help, because I had intermittent temps and sensor replacement fixed mine.
flyndeere
Posted 7/4/2017 16:12 (#6105442 - in reply to #6105148)
central illinois
My 4430 did the same thing, just tapped it with my fist started working but sometimes it will need a tap. Looks like same gauge always thought it was the gauge but never replaced it that was 7000 hours ago.
wire farms
Posted 7/4/2017 16:19 (#6105448 - in reply to #6105079)
Nebraska
Mine goes up into the red sometimes and it beeps and I know its not hot, so I just turn the flashers on for a few seconds and it goes back to normal, been doing this for almost 10 years lol
try turning your flashers on haha
jcwag
Posted 7/4/2017 17:30 (#6105542 - in reply to #6105079)
Upstate Ny
My 4450 has two sending units for the temp gauge. Did you change both???
jd43
Posted 7/4/2017 19:48 (#6105774 - in reply to #6105079)
Northeastern Pa.
That whole side of the panel gave us trouble so we put an automotive oil and temp gauge on the left side above the small door.
Rob D
Posted 7/4/2017 19:48 (#6105776 - in reply to #6105079)
s.c. north dakota
My 83 4450 does the same thing, I put a mechanical gauge in the extra fitting on the intake. inexperienced help get all excited and call then I ask what the extra gauge reads
ronm
Posted 7/4/2017 20:10 (#6105825 - in reply to #6105542)
Fruita CO
If it has 2, do away with the one on the water manifold. Can't remember if you just disconnect it or jump the wires on the sender together...there was a service bulletin on this, later tractors only had one temp sensor.
Somebody better jump in here...I don't have the bulletin & CRS has kicked in.
Posted 7/5/2017 00:21 (#6106222 - in reply to #6105542)
Central ND
late model in 1988 with investigator II dash. No I only changed one sender on the head of the engine.
