Search Forums | Classifieds (210) | Skins | Language
JD 6430 hot hydraulic oil
Suey
Posted 6/21/2017 10:01 (#6082237)
Subject: JD 6430 hot hydraulic oil
WCIL
I spray with a 6430  and a hydraulic  sprayer pump.   When the outside temperature gets above  90  the hydraulic oil gets hot and warming light comes on.  The hydraulic cooler is small and is mounted by itself in front of the radiator.   I asked the service manager about a bigger oil cooler and he didn't have any solution.   It seems like a larger oil cooler should solve the problem.   How would I get this done?   I would like to hear from someone who has had this problem and solved it.
1800swath
Posted 6/21/2017 10:15 (#6082261 - in reply to #6082237)
Subject: RE: JD 6430 hot hydraulic oil
Fulton County Ohio
You are running an open center hydraulic system. Do you have the correct orifice restricting flow to the sprayer? That tractor has two water pumps. One for the engine and one for the tranny. The one to the tranny can air lock and cause overheating. If a hydraulic lever is engaged but oil is not allowed to flow on this model it will overheat. I assume all your radiators and screens are clean. Good luck
750driller
Posted 6/21/2017 10:18 (#6082265 - in reply to #6082261)
Yes check to make sure you have the right orifice for the hydraulic pump on the sprayer.
redblooded
Posted 6/21/2017 10:22 (#6082268 - in reply to #6082237)
Shelburne Ontario Canada
make sure ur coolant is full is wat i was told
kagen
Posted 6/21/2017 11:11 (#6082320 - in reply to #6082237)
Panhandle of Ne.
If possible, turn the hyd flow down as low as possible so that everything will still work properly and see if that helps. Did that I on my r series tractor yesterday and it helped a lot
ccjersey
Posted 6/21/2017 11:12 (#6082321 - in reply to #6082265)
Faunsdale, AL
X2. ......check that the bypass screw is backed out on the hydraulic motor of the spray pump. Running the motor doesn't heat the oil up per se, its the excess flow going through the system relief valve and the whole system operating at relief pressure that causes the extra heat. If the motor bypass cannot be opened up enough to keep the pressure down, a flow divider installed in the circuit to the motor might be required.
The other question is are you somehow bypassing the oil cooler the way you have the return flow from the motor plumbed into the tractor.
Check the application instructions for the spray pump. The manufacturer probably has a solution.
Edited by ccjersey 6/21/2017 12:01
elm@tree
Posted 6/22/2017 05:23 (#6083519 - in reply to #6082237)
Had same problem with our 6415(I know ,smaller pump) but the problem was a leaking valve in the rear . It took Deere 3 weeks & many thousands of dollars to figure it out.
RickD
Posted 6/23/2017 21:12 (#6086808 - in reply to #6082237)
NE Kansas
Our 6430 did the exact same thing last year on hot days. Didn't do anything to it and it did it again this year one day. The 6430 has a bad habit of getting an airlock in the water system resulting in not cooling properly. The temporary cure is to burp the system. There is a metric allen head plug under the radiator just to the right of center. Turn the plug loose and run the tractor watching the overflow tank, do not let it get low or you will have to repeat the process. We have had to do this several times over the years. I don't know yet if it cured our hot hydraulic oil problem yet.
