Search Forums | Classifieds (83) | Skins | Language
925F header hookup.
Big Buck
Posted 6/3/2017 15:31 (#6052091)
Subject: 925F header hookup.
Eastern Ontario
So I'm just looking for some clarity here. I've got a 90' 9500 with currently a 915 platform on it. I'd like to put a 925F on it. Can someone explain to me the differences and if the hookup would work on my 9500. From pictures it looks like a 925f has some sort of pto shaft hook up rather than the double chain I'm used it.
Indrtfmr
Posted 6/3/2017 15:38 (#6052103 - in reply to #6052091)
Subject: RE: 925F header hookup.
NW in.
There are adaptors available to make it work.
Sandcraft
Posted 6/3/2017 15:50 (#6052121 - in reply to #6052103)
South Central ND
+1 they bolt on the chain sprocket on the combine and the pto shaft slides on. Someone used that header on a newer combine and switched the chain drives to pto.
farmerpope
Posted 6/3/2017 16:45 (#6052172 - in reply to #6052121)
Whitewater MT
agree i think you can find them on slaon express or shoup
spellfarms
Posted 6/3/2017 16:58 (#6052191 - in reply to #6052091)
Central Iowa
Most later models have different electrical hookups also. if it has a big round plug instead of the little one your 9500 has, it uses potentiometers instead of the black box. You will either have to convert it back or put headsight on your combine
Big Buck
Posted 6/3/2017 17:37 (#6052232 - in reply to #6052191)
Eastern Ontario
Thanks. I appreciate the help
bmatteson
Posted 6/3/2017 17:44 (#6052245 - in reply to #6052232)
NEND
There's an adapter harness to make the header height system and lights work, I used one on my 9610. Lankota makes PTO adapters for the drive shafts
Posted 6/3/2017 18:48 (#6052323 - in reply to #6052091)
PTO stub shafts are 2 piece and bolt to the chain couplers.
920 platform still has level land chain drives but this 693 has PTO drives the adapters work very well and bolt to the chain sprockets on the combine.
JD8345
Posted 6/3/2017 21:12 (#6052574 - in reply to #6052091)
I just put a 925F on a 96 9500. What you will all need is the bolt on pto adapters. For the electrical side, I converted my head back from the newer pentiometer cost about 350 dollars from Deere and very easy to do. You will get the black box style dial a matic box and then a plug and play 31 to 16 pin adapter fro head to combine. I can send pictures of you need any. It is not to hard to do.
jd7810
Posted 6/3/2017 21:22 (#6052602 - in reply to #6052091)
210 Industrial Dr., Arlington Wisconsin 53911
Deere at one time made half shafts - pto knuckle on head side and the chain coupler on the combine
side. They should be available used and maybe from Lankoda.The pto adapter as mentioned will work too.
Your combine probably has dial-a-matic with the 3 position switch in the combine. If the head has the triangle
shaped box on the right side and the right connector to plug into the combine it will work. If it has the
bell crank style switches on the right side ( active header height) then you need the kit from headsight or
at one time there was a kit to switch back to dial-a-matic. It consisted of the dial-a-matic box, harness, the
small divider, and the underside plate just behind it. I have switched several over the years when Headsight
company didn't exist. Many later 925's had contour master set ups on the head for combines
that had feeder houses that tilted so that set up may be on the head. If it is you will see a bell crank style
switch on the left side. Last many newer heads have single point hook up on the back of the head. you would
need to convert this if it has that on it.
Edited by jd7810 6/3/2017 21:25
ndred
Posted 6/3/2017 22:39 (#6052752 - in reply to #6052602)
s nd
No email address. This is laying around.
(deere header adapter.jpg)
Attachments deere header adapter.jpg (80KB - 178 downloads)
Big Buck
Posted 6/4/2017 03:16 (#6052865 - in reply to #6052752)
Eastern Ontario
Where abouts are you located. I from eastern Ontario Canada
Big Buck
Posted 6/4/2017 03:20 (#6052867 - in reply to #6052752)
Eastern Ontario
I updated my email
