Search Forums | Classifieds (18) | Skins | Language
john deere 7200 planter markers
R S FARM
Posted 5/8/2017 06:06 (#6006185)
Subject: john deere 7200 planter markers
Just got a 8 row 30 inch row 7200 vacuum planter. When raising the planter on the end, The right side marker slams pretty hard when raising up. The hydraulics are slowed down. The left side bangs a little when raising. Should I shorten the right side cable ? Deere doesn't have a rubber bumper there. Thanks for the help.
Posted 5/8/2017 06:45 (#6006241 - in reply to #6006185)
Subject: RE: john deere 7200 planter markers
Here is my post about it with additional links to post, the valve and video of before and after.
https://talk.newagtalk.com/forums/thread-view.asp?tid=549000
Get a hydraulic flow control valve that controls flow in one direction and plumb it to control flow raising marker.
http://www.surpluscenter.com/Hydraulics/Hydraulic-Valves/Flow-Control-Valves/1-4-NPT-5-GPM-PRINCE-WFC-400-IN-LINE-FLOW-CONTROL-9-7960-4.axd
The orifice where the hose goes into the frame of the planter only controls drop rate.
This way you can dial in the raise speed you want and take the slamming out of the markers. Works like a dream and saves a lot of abuse on the marker arm and steel bumper stop.
Here is a close up of the valve courtesy of Surplus Center.
Here is the photo album you should be able to click on the .wmv files and they will play directly without having to download.
http://imageevent.com/vprb/hydraulicmarkerflowcontrol
(Valve.JPG)
Attachments Valve.JPG (24KB - 155 downloads)
jd7810
Posted 5/8/2017 20:19 (#6007330 - in reply to #6006185)
210 Industrial Dr., Arlington Wisconsin 53911
Could be wrong but I haven't seen a 7200 style planter with cable markers. Are you
talking about a 7000?
Posted 5/8/2017 20:51 (#6007409 - in reply to #6007330)
No I have a early 7200 standard planter 6 row with cable markers.
Not sure about original posters machine but the valve I mentioned would work for a 7000 also to keep from slamming markers up.
jd7810
Posted 5/12/2017 22:08 (#6014783 - in reply to #6007409)
Von Right you are about a 4 or 6 row conventional frame with cable markers but
he has an 8 row. All 7200 8 rows and larger all had hydraulic markers with the ram
in the marker arm. 7000 8 rows were cable.
Posted 5/12/2017 22:59 (#6014856 - in reply to #6014783)
Probably my mistake I saw he mentioned shortening the cable and I thought of internal cable while he probably was referring to cable that lets the longer marker fold in the middle.
At any rate the valve I mentioned should still work to control the flow bringing the marker up and stopping the slamming action that he is seeing.
