West KY | What cable do I need to get speed from the green star to the raven 450. And is there a way for the 2630 to paint coverage of what sections are turned on. Will be on a 17 knife nh3 applicator with 3 sections |
Butterfield, MN | I believe that you'll need the Field Doc Connect kit from John Deere to do that. It should paint the individual boom sections and keep track of the rate across the field. I believe that a cable is needed from the receiver to provide GPS speed to the 450. Someone more familiar with those can probably give you a part number of that cable. |
Slicker than a Yes album. | You also need to make sure your 450 has a serial port on the back for the Field Doc connect to plug into. Might be able to find a kit used in the classifieds since most have gone to a Rate Controller and left the 450 on the shelf.
(images.jpg)
Attachments ---------------- images.jpg (5KB - 178 downloads)
WC MN | PF90363 |
