AgTalk Home | ||
Let's see your commodity sheds!! Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forums List -> Stock Talk | Message format |
wbstofer |
North Central IN | Thinking about building a shed this summer for distillers, soyhulls, ground hay, and other feed ingredients, just looking for design ideas. I'm thinking 3 walls of concrete with a pad out front. Just looking for design, dimensions, heights of concrete and shed, and how big to make pad out front. Would like to hold a semi load of distillers. How big is necessary? Dumping with end dump trailer, have a Bobcat to push it up if needed. Thanks!! | ||
CanadianCowMan |
Chilliwack BC Canada | Following | ||
cldairy |
west michigan | We built ours with four 12 foot wide bays. Building is 36 feet deep and each bay easily holds a semi load of anything. Concrete walls are 8 feet high with stud wall on top, back wall is 12 feet total height, front I think is 20 feet. We extended the roof over the front to help keep rain and snow out. Floor is slopes slightly from back to front inside and then the approach slopes a little more aggressively away, can't remember the exact slope. We started with a 30 foot pad out front, and later extended it to 80 feet for a mixing pad. The more room you can give trucks the better. Our roof height is not high enough for an end dump to get all the way in, but it hasn't been a problem because most of our feeds comes in on auger truck or belt trailer. I would suggest building it with more bays than you think you'll need, nice to have an empty bay just in case an opportunity comes up. Plus you can always find something to put in there! (IMG_0689.JPG) (IMG_0690.JPG) (IMG_0691.JPG) Attachments ---------------- IMG_0689.JPG (121KB - 641 downloads) IMG_0690.JPG (88KB - 740 downloads) IMG_0691.JPG (120KB - 581 downloads) | ||
agbuilder |
Eastern NE | This one is not mine and not quite done yet. Building for a dairy. (IMG_7592.JPG) Attachments ---------------- IMG_7592.JPG (96KB - 610 downloads) | ||
dabeegmon |
SE Manitoba | agbuilder - 2/20/2017 10:05 This one is not mine and not quite done yet. Building for a dairy. That is bloody huge!!!!! If you put the spike needle belts (really don't know what they are called) that are at public train stations in Europe on top of those concrete dividers there should be little bird issues in that cavern! | ||
garvo |
western iowa,by Denison | nothing fancy just a hammer and some crete-we don't have no hard hats or employees (001 (Small).JPG) (002 (Small).jpg) (006 (Small).jpg) (008 (Small).jpg) (010 (Small).jpg) Attachments ---------------- 001 (Small).JPG (71KB - 658 downloads) 002 (Small).jpg (115KB - 515 downloads) 006 (Small).jpg (76KB - 560 downloads) 008 (Small).jpg (97KB - 657 downloads) 010 (Small).jpg (74KB - 592 downloads) | ||
garvo |
western iowa,by Denison | more (002 (Small).JPG) (003 (Small).jpg) (004 (Small).jpg) (002 (Small).JPG) (004 (Small).jpg) (007 (Small).jpg) (018 (Small).jpg) (019 (Small).jpg) Attachments ---------------- 002 (Small).JPG (67KB - 688 downloads) 003 (Small).jpg (78KB - 517 downloads) 004 (Small).jpg (66KB - 662 downloads) 002 (Small).JPG (53KB - 648 downloads) 004 (Small).jpg (59KB - 594 downloads) 007 (Small).jpg (67KB - 588 downloads) 018 (Small).jpg (80KB - 633 downloads) 019 (Small).jpg (61KB - 645 downloads) | ||
garvo |
western iowa,by Denison | more (002 (Small).JPG) (003 (Small).jpg) (005 (Small).jpg) (008 (Small).JPG) (009.jpg) (011 (Small).jpg) (012.jpg) (014 (Small).jpg) (015 (Small).jpg) Attachments ---------------- 002 (Small).JPG (58KB - 643 downloads) 003 (Small).jpg (53KB - 709 downloads) 005 (Small).jpg (65KB - 680 downloads) 008 (Small).JPG (84KB - 660 downloads) 009.jpg (111KB - 734 downloads) 011 (Small).jpg (79KB - 680 downloads) 012.jpg (92KB - 652 downloads) 014 (Small).jpg (73KB - 767 downloads) 015 (Small).jpg (67KB - 750 downloads) | ||
roo |
Cullom, Illinois | 5 bays plus a mechanical room for the Harvestore unloader and bagged feed. (IMG_0063.JPG) (IMG_0070.JPG) (IMG_0065.JPG) (IMG_0068.JPG) Attachments ---------------- IMG_0063.JPG (88KB - 568 downloads) IMG_0070.JPG (112KB - 572 downloads) IMG_0065.JPG (129KB - 591 downloads) IMG_0068.JPG (131KB - 606 downloads) | ||
farmerjon52 |
Why square head nuts and bolts? | |||
garvo |
western iowa,by Denison | cheap | ||
Helland |
SE ND | Whats something like that cost to build? | ||
carlsoncl |
Beresford, SD | Very first building I built after buying my place from dad. It's about 15 years old. Middle bay is for tub ground alfalfa, South Bay has an elevated roller mill that rolls corn from bin......with three swithches. North bay was used for mod or ddgs....now I store tractor and tubgrinder in that bay. (IMG_0331.JPG) Attachments ---------------- IMG_0331.JPG (92KB - 589 downloads) | ||
crossbredFARMER |
Southern Wisco | 60 wide 30 deep built with bridge beams so when the dump trucks hit it they hurt the truck more than the building Edited by crossbredFARMER 2/20/2017 12:51 (image.jpeg) Attachments ---------------- image.jpeg (136KB - 670 downloads) | ||
cattlefeeder93 |
Eastern NE | . | ||
5 Head |
South West MN | build it bigger from the start. The box on the left side is for bulk mineral. (image.jpg) (image.jpg) Attachments ---------------- image.jpg (110KB - 605 downloads) image.jpg (121KB - 610 downloads) | ||
jocoshar23 |
SE IA | nothing fancy (bales.jpg) (grind.jpg) Attachments ---------------- bales.jpg (59KB - 545 downloads) grind.jpg (50KB - 641 downloads) | ||
Minnesotaboy |
SW Minnesota | +1 | ||
Minnesotaboy |
SW Minnesota | Carlson, do you have any pics of your elevated roller mill set up? | ||
carlsoncl |
Beresford, SD | Mill. Old pics....I've changed my liquid pipes since pic. Edited by carlsoncl 2/20/2017 15:26 (IMG_0343.JPG) (IMG_0342.JPG) Attachments ---------------- IMG_0343.JPG (86KB - 673 downloads) IMG_0342.JPG (72KB - 684 downloads) | ||
Minnesotaboy |
SW Minnesota | Thanks | ||
jcolli140 |
SC Wisconsin | Watching | ||
bsfarms |
south central WI | No pics here, but ours is 6 bays wide, 12' wide and about 60' long. The length is nice as I can have belt trailers back in and empty out and I don't have to handle anything. It sucks having to push feed in to get it to fit. Maybe they could hold the brakes and get it to pack, but it seems like they use the whole bay every time. If I push it in I can get about 2.5 semis of cottonseed in each. A big concrete apron with gravel past that hel p s. | ||
cihnick |
wc mn | 5 bay, 14 wide, 30 deep, 8 tall in the back, 14 tall in front. 20 foot apron. Built myself in 2011. Would be nice to have a extra bay or two at times but I have made this work for now. (IMG_20170119_085912541.jpg) (IMG_20161129_083856940_HDR.jpg) Attachments ---------------- IMG_20170119_085912541.jpg (261KB - 606 downloads) IMG_20161129_083856940_HDR.jpg (263KB - 555 downloads) | ||
Direct Injected |
SW, Missouri | . | ||
ThomasJW |
Central BC | Just got into it November. 20 & 16' wide bays, 50' deep, 16' overhang, 40' leanto, 20' insulated bay, and a few bunkers. (IMG_1003.JPG) (IMG_1001.JPG) (IMG_0796.JPG) (IMG_0861.JPG) (IMG_0412.JPG) (IMG_0995.JPG) Attachments ---------------- IMG_1003.JPG (74KB - 583 downloads) IMG_1001.JPG (73KB - 601 downloads) IMG_0796.JPG (125KB - 652 downloads) IMG_0861.JPG (113KB - 648 downloads) IMG_0412.JPG (196KB - 555 downloads) IMG_0995.JPG (106KB - 596 downloads) | ||
DC4020 |
Central Ga | . | ||
cldairy |
west michigan | Built in 2013, had 35k into it with the original 30 foot approach. Hired it all done. | ||
Wisconsindairy |
Freedom, WI | That looks like a pretty slick feeding setup! | ||
kneedeep |
Lynd Minnesota | Here is a few of mine Commodity shed is 36 by 72 with one side open. Outside walls are poured 4 foot tall. Dividing walls are 2x2x6 concrete blocks. Far left bay has wall framed on top of the blocks. Also included a few pics of a 18 ft bin I use for minerals Edited by kneedeep 2/21/2017 09:38 (IMG_0385.JPG) (IMG_0380.JPG) (IMG_0389.JPG) (IMG_0377.JPG) (IMG_0378.JPG) (IMG_0379.JPG) (IMG_0387.JPG) (IMG_0386.JPG) (IMG_0394.JPG) Attachments ---------------- IMG_0385.JPG (97KB - 588 downloads) IMG_0380.JPG (101KB - 633 downloads) IMG_0389.JPG (123KB - 598 downloads) IMG_0377.JPG (100KB - 644 downloads) IMG_0378.JPG (119KB - 591 downloads) IMG_0379.JPG (84KB - 621 downloads) IMG_0387.JPG (92KB - 569 downloads) IMG_0386.JPG (87KB - 608 downloads) IMG_0394.JPG (123KB - 525 downloads) | ||
Minnesotaboy |
SW Minnesota | What do you put in the bin? Any more pics of the bin? How did you do the doorway? I have a bin here I'd like to do something with | ||
kneedeep |
Lynd Minnesota | I'm a feed lot. I have My r-800 mineral on the left and MGA pellets on the right. Bagged products in center ( wide enough for the skid loader to get in , designed for full pellets of bags ) such as CTC hydro-lac or whatever I my need. The door is a 8 ft roll up from menards. I will try to get more pics of door later Edit to add the door is in the brown box waiting to be installed in pics. I used treated lumber to frame the door opening with channel iron a few feet from the door each way to help stiffen the walls as I cut the opening. It really came together quite easy and inexpensive. Edited by kneedeep 2/21/2017 09:36 (IMG_0390.JPG) (IMG_0391.JPG) Attachments ---------------- IMG_0390.JPG (128KB - 739 downloads) IMG_0391.JPG (107KB - 825 downloads) | ||
Minnesotaboy |
SW Minnesota | Thanks for the pictures, a good way to make use of an unused bin | ||
sbfarms |
NW Wyoming | . | ||
jedstivers |
Marianna Arkansas | Good pics. I got to get something built. | ||
HuskerBeef |
Northeast Nebraska | Lots of good ideas and setups here. | ||
(Delete cookies) | |
