Search Forums | Classifieds (93) | Skins | Language
White 6175 transmission solenoid
Mbrath
Posted 2/8/2017 22:45 (#5826843)
Subject: White 6175 transmission solenoid
I have a 1994 6175 with 2800 hrs. Today in -35C weather I started it up to plow snow and the fail sensor light came on. Coded E37. We use it for snow plotting in the oil patch. Dealer says code says bad solenoid. Found out they are discontinued and Agco has no update numbers. Does anyone know if the solenoid after the serial number break will work? They look the same. The new ones are 6vdc. Are the old one 6 volt as well? If anyone as some experience with this it sure would be appreciated. Really cold trying to trouble shoot. Thanks
WTW
Posted 2/8/2017 23:39 (#5826888 - in reply to #5826843)
Subject: RE: White 6175 transmission solenoid
Winkler, Manitoba Canada
Have you checked the wiring and connections to the solenoids? Maybe just a bad connection.
Funk transmission was also used on the Genesis tractors so suitable parts might be available from New Holland or Versatile.
todd67648
Posted 2/9/2017 03:21 (#5826942 - in reply to #5826843)
Holy cow....A 1994 year model tractor and a shift solenoid is NLA. Now that's impressive manufacturing support.
gene_champ
Posted 2/9/2017 05:11 (#5826958 - in reply to #5826843)
NC Iowa
I do know that those solenoids are problematic. My white mechanic advised me to buy a 170 instead of a 6175 because of the solenoid issue. I didn't know they were nla though.
Jon
Posted 2/9/2017 06:36 (#5827016 - in reply to #5826843)
Callao Missouri
Plug & unplug the two large wire harness connectors on the outside of the firewall of the cab right in front of the clutch peddle. Also I have had no problem's getting them for a 9630 Agco Allis. Ford, Massey, white, Agco, and some fertilizer trucks, as well as some construction equipment used that same transmission. I would check a different dealer. Sometimes parts availability is only as good as the nut behind the computer key board. Jon
Kelly
Posted 2/9/2017 07:25 (#5827098 - in reply to #5826843)
NC KS
The newer solenoids work, you just have to connect the wires some how as the older ones didn't have a connector on them. That is the only difference. The only way a dealer will have an older one in stock is old inventory.
Solenoid should be magnetized when voltage is applied.
Edited by Kelly 2/9/2017 07:26
kneedeep
Posted 2/9/2017 07:55 (#5827164 - in reply to #5826843)
Lynd Minnesota
I don't know your location but have you called maibach tractor?
Lots of knowledge of white tractors in that place.
Kelly
Posted 2/9/2017 11:58 (#5827762 - in reply to #5827098)
Subject: Update
NC KS
I was around my older tractor today. You will need a 2 pin connector to go with the later model solenoid. Should be able to get the first at the dealer. Rest of them can be sourced elsewhere as soon as you figure out the name of it.
Newer solenoids have the plug on the solenoid for wiring harness. Older ones have wires coming out of them without a connector nearby. There was a solenoid number that had the connector and a pigtail included in the box but maybe that is the one that disappeared.
GM Guy
Posted 2/9/2017 19:01 (#5828619 - in reply to #5826942)
NW KS/ SC ID
todd67648 - 2/9/2017 02:21
Yes, just like CIH Steigers with the manual transmission having many NLA parts. Tell me how this is a White only problem again? :)
Edited by GM Guy 2/9/2017 19:01
Deadeye
Posted 2/9/2017 21:50 (#5829260 - in reply to #5826843)
Central Todd County MN.
The solenoids on a Gleaner Combine look the same. I used some to test the ones on the tractor we had.
