Search Forums | Classifieds (15) | Skins | Language
New Holland Windrower questions
stripfarmer
Posted 2/7/2017 07:48 (#5822549)
Subject: New Holland Windrower questions
west central wisconsin
Good morning all
We currently have a HW345 mower with a 16 foot cut, 2355 header.  We were gonna send the unit in for some winter service.   Now, we are considering trading headers, and or the entire unit.
It's got 1250 engine hours, and has been a good machine.  A few oil leaks, need to be addressed and we were gonna put new shafts in the header, between the modules.
Wondering about the good bad and ugly of the mowmax heads.... or durabine heads.  Looking at the 16 foot again.  We have a few rocks on some farms.... usually not too bad as we try to keep them picked.  The quick change knives looks slick, but wonder if they work good with age?
We've always had skids on the heads, and dealer is saying once guys go to rollers, they never go back.  One friend said they had a head with rollers and hated them!
If we trade tractors, we'd get either the 220 or 260, and again, words of wisdom?
We won't be trading brands but are trying to decide between repairing or replacing, and may only do just the head.  We have one offer to trade just heads, and it seems fair, as most dealers won't even consider offering anything for a used head, and I can't argue with that.
Thanks for any input
durallymax
Posted 2/7/2017 08:30 (#5822653 - in reply to #5822549)
Subject: RE: New Holland Windrower questions
Wi
We're you doing the cross shafts yourself or paying to have them done? If you can trade headers reasonably it may be worth it, even after the money you stick onto rebuilding, they don't seem to last as long, modules start to fatigue, more money goes into the cutterbar. The newer cutterbar is supposed to be better than the older ones were. I wouldn't worry about quick change knives, they've been used by others for many years and are worth every penny. I didn't see the roller option on their site, Skids work fine if float is set right, easy to rebuild too.
stripfarmer
Posted 2/7/2017 08:46 (#5822695 - in reply to #5822653)
We would hire the cutterbar work done, and we're thinking like you.... other components get wore where shafts Couple at modules. I only shear a couple shear hubs yearly.... only one on 3 crops last year, then 4 on one rock at seasons end on a seeding. Like you mention on header float..... it's key for skid wear and hitting obstructions. During a trade would be a great time to add rollers if they were the cat's meow.
Thinking strongly about trading heads vs spending a nickel on it and appreciate the input.
strawberry red
Posted 2/7/2017 08:50 (#5822699 - in reply to #5822549)
sc Washington
The new headers are an improvement over the 2355 headers. Quick change knives are a good thing. Around here very few people run rollers almost all run skids. I think the new headers would be worth it even at no trade.
discbinedr
Posted 2/7/2017 09:06 (#5822742 - in reply to #5822699)
SE PA
Used headers usually bring a few thousand on auctiontime.
SDFMEnterprises
Posted 2/7/2017 11:05 (#5823020 - in reply to #5822549)
KS/ NENE
I would agree if trade price seems fair, to do that. You won't get the life out of a re-built bed vs a new bed. Do you road a lot? The new machines go faster down the road, but they are much more squirrely at the higher speeds, just takes getting used to. How many acres do you run and what do you cut? I don't know if you will see enough performance gains from the 220 to the 260 to justify the cost difference if you don't run that many acres and cut mainly alfalfa and lighter crops.
jessbob1
Posted 2/7/2017 17:22 (#5823619 - in reply to #5822549)
NWWI
Durabine headers I think are a little more solid consruction at the mods, they are held together almost like a cradle compared to your 2355.
I am sure on your 2355 if you put shafts in between mods the mods will more than likely be leaking oil which means the bearings will be loose and are starting to eat at the seals. Even just replacing shafts is still a bandaid on the worn gearbox/ mod splines anyway.
I think the durabine headers have 20" turtles vs the 14" or 16" on 2355
The shear hub is a larger diameter also than your 2355 and knives are different also, so those parts will not interchange
mnag15
Posted 2/8/2017 09:08 (#5825011 - in reply to #5822549)
I would think just replacing the cutterbar could be a cost effective option. We have been fighting cutterbars on our 2 SP windrowers that have over 15,000 acres on them. It is my understanding that at some point that replacing just a few shafts or even a few modules with worn gears really doesnt solve your problem if the rest of the cutterbar is worn. A hay cutter is one of those things that has to work when you need it to.
