Search Forums | Classifieds (132) | Skins | Language
Accessory power plug for Tractor Cab power
rosiesdad
Posted 1/30/2017 11:22 (#5804753)
Subject: Accessory power plug for Tractor Cab power
Western-Central Lower Michigan
Looking for reasonable priced accessory plug for cab power. Its the one that us under a screw cap, three terminals. Cant believe they are supposed to cost $50+
Two Hawk
Posted 1/30/2017 12:54 (#5804913 - in reply to #5804753)
Subject: RE: Accessory power plug for Tractor Cab power
Southern Nevada desert
3 pin amp connector
http://www.shoupparts.com/AE1239/
http://www.shoupparts.com/AE1238/
http://www.sloanex.com/planter-parts/harness-connectors/amp/3-pin-a...
edit to add
These are cheap but you need to add the pins
http://www.digikey.com/product-detail/en/206037-2/A1685-ND/241465?W...
Edited by Two Hawk 1/30/2017 13:00
Two Hawk
Posted 1/30/2017 14:19 (#5805055 - in reply to #5804753)
These are nice if you need extra outlets
http://www.shoupparts.com/AE6601/
rosiesdad
Posted 1/30/2017 18:25 (#5805558 - in reply to #5804913)
Thanks, had earlier today specifically asked Shoup if they had these... (my description was verbal) but called just before closing and added several to the order. Handy to have around.. But hard to find.
iowafarmk
Posted 1/31/2017 08:08 (#5806725 - in reply to #5804753)
Have a bunch of the 3 plugs in our tractor. Adapated it to the Deere style power strip. http://www.greenpartstore.com/John-Deere-Multi-Power-Outlet-Strip--... Easy and cheap to add extra outlets then.
