Search Forums | Classifieds (29) | Skins | Language
Putting floaters on 4830 JD sprayer?
simple man
Posted 1/13/2017 09:50 (#5764811)
Subject: Putting floaters on 4830 JD sprayer?
Was looking for the 650 60R 38s thinking they would be close to the same height as my 380 90 R 46s but not having any luck. THe 600 65 R 38 I found according to the spec sheet are about 3" shorter that my 380 90 s. Does this slow down my road speed by much? Is it noticeable? I understand the 600 s are what JD recommends for the hubs but the 650 look like they would be nice to run and still not have to remove fenders. Any tips?
Thanks
Edited by simple man 1/13/2017 09:51
rab1964
Posted 1/13/2017 10:20 (#5764863 - in reply to #5764811)
Subject: RE: Putting floaters on 4830 JD sprayer?
Don't know that I have really paid attention to it, but it seems like I can run right at 33 most of the time down the road with either one. 650 floaters.
Doingit4thegirls
Posted 1/13/2017 11:11 (#5764964 - in reply to #5764863)
I have 4 wheels and 3 tires for a 4830. There 650/65 r38. They work fine. It actually seems like it has more power and rides better. Call or text 270-635-0703. There for sale.
frmbig1
Posted 1/13/2017 11:55 (#5765046 - in reply to #5764811)
I run 600's on my 4830. Dont't notice much.
Edited by frmbig1 1/13/2017 11:55
Boone & Crockett
Posted 1/13/2017 12:19 (#5765109 - in reply to #5764811)
There's a set of good looking floaters coming up on a sale in Earlville, ILL next week I believe.
Edited by Boone & Crockett 1/13/2017 12:20
Tkrentzjr2
Posted 1/13/2017 13:43 (#5765295 - in reply to #5764811)
We have a set of Michelin 650 60R 38s on rims, they came off a 4730 with about 95% tread. Would love to sell
email me at [email protected]
EASmith
Posted 1/13/2017 17:57 (#5765678 - in reply to #5765295)
4730 and 4830 have different hubs/bolt pattern
GM Guy
Posted 1/13/2017 18:26 (#5765733 - in reply to #5764811)
NW KS/ SC ID
we have some 710s if you want bigger. check classifieds.
2 Bravo
Posted 1/13/2017 18:36 (#5765759 - in reply to #5764811)
Subject: Check your offset
Are you looking to upgrade to an R series sprayer in the future? If so, you might want to check to see if the offset on any floaters you find will fit a 4830 and a R4038. My understanding is a wheel fit for the R's offset will fit a 4830 and stick out an extra 2 inches, where a wheel fit for the 4830's offset will not fit the new R suspension. Anyone feel free to to correct me if I'm wrong.
IL Deere Driver
Posted 1/13/2017 19:02 (#5765821 - in reply to #5764811)
Go with 710's
(2013-4-24-2.jpg)
Attachments 2013-4-24-2.jpg (102KB - 190 downloads)
bigfarmer
Posted 1/13/2017 19:54 (#5765990 - in reply to #5765759)
Subject: RE: Check your offset
Ontario
2 Bravo - 1/13/2017 18:36
2 Bravo...you are correct.. r series will fit the 30's but the 30's won't fit the R's
We went with the R series wheels form harrys tire and wheel for our 4830.
Edited by bigfarmer 1/13/2017 20:00
KDD
Posted 1/13/2017 20:59 (#5766188 - in reply to #5765990)
Leesburg, Ohio
Exactly correct. We did the same.
simple man
Posted 1/14/2017 04:35 (#5766634 - in reply to #5765821)
Subject: IL DEERE DRIVER ..AFenders?
With the 710s being a little taller how do you clear the fenders? Did you modify the brackets. Like the looks of them.
IL Deere Driver
Posted 1/16/2017 17:46 (#5772570 - in reply to #5766634)
Subject: RE: IL DEERE DRIVER ..AFenders?
Used 1.5" square tube to put between fender brackets and the arms. Then put longer bolts in. Worked really well.
4DNC
Posted 12/12/2017 11:08 (#6423797 - in reply to #5765821)
Are they 710x38 or 710x32? Did the sprayer pull them alright?
IL Deere Driver
Posted 12/31/2017 16:39 (#6467619 - in reply to #6423797)
They are 710/38's. Sprayer handles them fine, but you do need the steering counterbalance kit, I believe it is called. Without that it will walk like a duck. We also installed 1.5 or 2" square tubes between the fenders and the fender brackets so we could run the fenders all the time.
farmerboy50
Posted 12/31/2017 16:46 (#6467636 - in reply to #5764811)
West Texas
Classifieds, there is a set of 650s for 6500.
Gregoire Farms
Posted 7/22/2019 09:14 (#7628443 - in reply to #5772570)
Would you happen to have a pictures of your modified fender brackets? I just got myself some 710's for my 4830 and curious to see how you did it
IL Deere Driver
Posted 7/24/2019 14:38 (#7632574 - in reply to #7628443)
Sorry, when I saw this I remembered you had emailed. I will get you some pictures.
Licensed to kill
Posted 7/24/2019 19:00 (#7632885 - in reply to #5764811)
Northern Alberta
I run 320's and 600's on my 4830. The 320's are a bit taller and run about 1MPH faster than the 600's in 3rd gear. Don't know about 4th as I rarely road my machine and haven't paid any attention when I do.
