AgTalk Home | ||
Replacement tire size for 9.00 x 20 truck tires? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
jd-tom |
SW Minnesota | I have a 1979 Ford L700 single axle truck with an 18' grain box on it. It still has the usual 20" split rims on it with 9.00 tires on Dayton wheels that most trucks of this vintage were equipped with. Since it is getting very hard to find tires for it anymore, I purchased a set of 22.5 rims that will fit on the Dayton spoke center but still need to find the correct tire size to put on them. So that is my question - what radial tire size would be the closest to the original 9.00 x 20 tires? The replacement 22.5" tires will have to be roughly the same height (plus or minus and inch or two) and also since they are radials, they cannot be too wide and touch "cheek to cheek" when under load. TIA for your suggestions. | ||
Big Ben |
Columbia Basin, Ephrata, WA | A 22.5 lo pro like a 275/80R22.5 or 295/75r22.5 should be awfully close of not the same size as the old 9.00-20. Maybe go with the 275 if you're worried about the sidewalls touching. Edited by Big Ben 1/9/2017 23:52 | ||
KRMN FARMN |
Central nebr | 295/75/22.5 is the same as a 10-20 | ||
PatCMO |
Pilot Grove, Missouri | 10R22.5 is the same height as 9.00x20. Not sure what the metric equivelant is. 11R22.5 is the same height as 10.00x20. Patrick | ||
Erik in SD |
East Central SD | May I ask where you found the rims? New or used? I may be looking at doing the same. | ||
E718 |
Sac & Story county IA | That size is popular on school buses. They take off tires that would run a long time for farm service. Watch at shops that do bus work. | ||
cornerpost |
SE MN Still in Pothole Country | I have some very good 9.00 x 20 grips off a truck I junked out because of hoist, steering box, and frame issues that cropped up all at once. Contact in profile. | ||
Big Ben |
Columbia Basin, Ephrata, WA | KRMN FARMN - 1/9/2017 22:14 295/75/22.5 is the same as a 10-20 No, 10-20 is the same OD as an 11r22.5. The LP tires are a little smaller. | ||
Tired of Working |
Central Sask. RM#254, Canada | The changeover Dayton rims from 10.00x20 to 11R22.5 are only $100.oo brand New , Narrower ones for the 9.00 are likely the same $ . Borrow one with an 11R tire on it and see if you can go up the one size for clearance ; There are lots of decent used 11R22.5 tires around if you don't mind them not all looking exactly matching . Then you will legally carry more weight .. | ||
Reyem |
SW IA | Some schools have their own shop. My son bought some for a pup trailer direct from the school. | ||
Big Square |
Eastern Half of Kansas | 10r22.5 would be height and width replacement. Those would go on a 7.5x22.5 wheel. You could also, put on the sizes Big Ben mentions, 275 and 295, those are the same height as your originals, a little wider. You shouldn't need a wider spacer on the back axle. Those would ideally go on a 8.25x22.5 wheel. Used wheels unpainted up from junk yard are $40-50 for others asking. Edited by Big Square 1/10/2017 11:51 | ||
jd-tom |
SW Minnesota | Erik in SD - 1/10/2017 06:46 May I ask where you found the rims? New or used? I may be looking at doing the same. I got my rims at Erickson Truck Salvage near Jackson, MN. They were good used ones. | ||
redneckfarmer |
missouri | i put 255-80-22.5 on in place of 9.00-20's and the new metrics are maybe 1 inch shorter which was fine in my case so i have a slower 1st and reverse and a little more power. | ||
730diesel |
NE ND | Luckens in Winger, MN sells used rims like this for $40. I've done many. Yes, 10R22.5 is correct. Specs listed above sound right. | ||
mailman13 |
West Central Iowa | ... | ||
(Delete cookies) | |
