shoup vs local jd opener disk bearings
coastalBend
Posted 12/28/2016 19:28 (#5728691)
Subject: shoup vs local jd opener disk bearings
south texas
I think i shimed blades to tight with the 3.5mms. Doing 1.5in now. Some bearing housings are worn as well, some shiming with coke or beer cans will take it up.
Jd has new bearings for 8.75
my local supplier 8.50
shoup 5.95
my local guy says his are one grade below NTN. $2.50 is alot of difference if his and shoup are same quality. Disks are 14.75, i will probably run them to 14-14.25 if grains stay low priced. Anyone have quality issues with shoup?
im working on 2nd planter with 32 rows. Hopefully less than 1/4 need replacing. First one was 5 out of 16
Edited by coastalBend 12/28/2016 19:29
loran
Posted 12/28/2016 19:33 (#5728706 - in reply to #5728691)
Subject: RE: shoup vs local jd opener disk bearings
West Union, IOWA FLOLO Farm 52175
Shoup has always worked here....
But
Heck if you're going for cheap....
https://www.thebigbearingstore.com/204ry2-204fvmn-special-ag-bearing...
Assuming these are older steel row units, Cast shanks take heavier bearing
Edited by loran 12/28/2016 19:35
constructionfrmr
Posted 12/28/2016 19:38 (#5728724 - in reply to #5728706)
Nashville, IL
Can't say on opener bearings, but I will say you get what you pay for. We went the cheap route on closing wheels for our planter this year. Half the wheels needed new bearings. Other half might have made it. We bought from Sloans Express. Can't say anything bad about them because they offered to refund the money. Changed all 72 wheels. 1200 acres of corn and they were falling off the planter. Ended up replacing half or so with the ones I took off to get thru planting. Very disappointed in them. We bought the wheel and bearing for what a bearing would have cost from John Deere. Would have been better off putting bearings in our old wheels.
loran
Posted 12/28/2016 19:47 (#5728751 - in reply to #5728724)
I'd argue that...... I know 1 company tried offering a better blade this yr, on the production model.....
Prototype had .....Shoup blades....
Half the hub caps fell out before we left shop...... 150a on a 30' bar..... we had bearing going out, and the longest made 1500...... most blade are junk at 1000, but I figured let see how far the lasted.
German Shepherd
Posted 12/28/2016 20:16 (#5728835 - in reply to #5728691)
I've always been a big proponent of Shoup,  but I now get my opener blades and closing disks from CIH because of bearing troubles.  Can't say what they use for JD, but those cheap Chinese bearings in the Shoup blades and disks sometimes didn't even make it 2 days.   Started having trouble a couple years ago.
Edit:   Meant to say Shoup bearings have a problem, not CIH
Edited by Sheep Herder 12/28/2016 21:59
boothill
Posted 12/28/2016 20:51 (#5728951 - in reply to #5728835)
bootheel of Missouri
Sheep Herder. You buy your openers from CIH because the Chinese bearing don't last 2 days in the CIH . Hope I read this wrong
Roguesfolly
Posted 12/28/2016 21:55 (#5729153 - in reply to #5728691)
Nw Ks
I bought 48 complete opening discs from Airseeder Guys last Dec. because they used Ingersol blades for 1770XP. Looked good and worked good till 2000 acres (85/row) then replaced 16 bearings. Neighbor had same problem. I went back with Deere bearings. After 3000 acres they measure 14 7/8" or more. Conclusion was good blades, Chinese bearings.
German Shepherd
Posted 12/28/2016 21:59 (#5729160 - in reply to #5728951)
I edited it now.   Thanks for pointing out my error.   It's the Shoup bearings that don't stand up.
SSI
Posted 12/29/2016 13:31 (#5730275 - in reply to #5728691)
new blades measure 15" and are recommended to be replaced at 14.5". If you go beyond that then you will see several issues including,
  • cutting a W in the trench vs a V = poor depth
  • dull opener hair pining residue vs cutting through residue
  • worn seed tube guard allowing openers to wear on the seed tube = seed deflection out of trench
  • worn seed tube guard breaking seed tube alignment hook = seed tube bouncing back and forth.
No experience on JD vs Shoup but your comment caught my eye on running openers oil 14"
coastalBend
Posted 12/29/2016 19:56 (#5731006 - in reply to #5728691)
south texas
Chickened out and went with local. Kml at 8.50. Have steel seal protection for bearings. Im finding more loose bearing in the housing vs failures. The 3.5mm disks seem to get 1.5-2" of contact if they are shimmed tight or loose. Im going by feel now. Shimming them till they slip with minimal effort.
NEIACropfarmer
Posted 12/29/2016 20:56 (#5731212 - in reply to #5731006)
We have had lots of trouble with the shoup bearing housings come apart from the blades. Some shoup parts are good, but some have been junk....
