Search Forums | Classifieds (3) | Skins | Language
JD 4250 Telesoping steering column
bleedgreen720
Posted 12/14/2016 22:30 (#5698592)
Subject: JD 4250 Telesoping steering column
AB.
Had to replace the plastic sliding piece in the dash so got the steering wheel off and the center rod slid down in the column. No big deal it came back out the hole when I shortened the column. Got the wheel back on and wen to put the center spinner on and the rod isn't out far enough to come through the spinner. Long story short it is stuck in there hard. Anyone ever had one of these apart or have a diagram breakdown of the column
Edited by bleedgreen720 12/14/2016 22:54
LNS8310
Posted 12/14/2016 23:01 (#5698652 - in reply to #5698592)
Subject: RE: JD 4250 Telesoping steering column
N.C. Iowa
He is a couple parts breakdowns.
Edited by LNS8310 12/14/2016 23:05
(42501.gif)
(42502.gif)
Attachments 42501.gif (116KB - 739 downloads)
Attachments 42502.gif (85KB - 719 downloads)
bleedgreen720
Posted 12/14/2016 23:07 (#5698661 - in reply to #5698652)
AB.
Thanks. Have got the parts list to go with that? Wish i had not started this "little" project now.
Two Hawk
Posted 12/14/2016 23:35 (#5698687 - in reply to #5698661)
Southern Nevada desert
I think 4 and 5 in the first pic may need to be indexed properly so the wedges match
LNS8310
Posted 12/14/2016 23:46 (#5698691 - in reply to #5698661)
N.C. Iowa
Should done that the first time, hopefully this helps.
John Deere - Parts Catalog
Printer Friendly Page
Close Window
Catalog: 1901 | Grid: 0 | Section: 60 | Page: 491
Catalog Name:4050, 4250 and 4450 Tractors (Engine:6466D,6466T,6359T)(Worldwide Edition)
Page Name:Steering Metering Pump, Shafts, Bearings And Seals
Direction of Travel:
keyPART NO.PART NAMEQTYSERIAL NO.405042504450REMARKS
1R72858Seal1 XXXSUB FOR R32730
2R50875Bushing1 XXX
3AR81184Tube1 XXX
4R62280Shaft1 XXX
5AR54808Rod1 XXX
6R62278Thrust Washer2 XXX
7JD8875Needle Bearing1 XXX
8R50869Splined Coupling1 XXX
9R42629Washer1 XXX
10P46402Snap Ring4 XXX
11R55498Bushing1 XXX
12R109986Shaft1 XXXSUB FOR R55092
13R56645Plate1 XXX
14R72820Shim1 XXX
15R72858Seal1 XXXSUB FOR R32730
16R27216Drain Plug1 XXXSUB FOR R72834
17R26287O-Ring1 XXX
18AR99334Base1 XXX
19R55243Shim2 XXX
20R58653Plate2 XXXUSE WITH AR89199; SUB FOR AR253735
 R58653Plate4 XXXUSE WITH AR201732
21R58654Spring1 XXX
22RE565814Pump1 XXXSUB FOR AR70507 OR AR99332
23R68220Fitting1 XXX
24R28776O-Ring4 XXX
25AR99335Cover1 XXX
26R26572Nut2 XXX
27R27296Nut2 XXX
2819H2023Cap Screw6 XXX3/8" X 3-1/4"
29R54763Fitting2 XXX
30AR88771Check Valve1 XXX
3114H1076Nut6 XXX3/8"
32AR201732Steering Metering Pump1 XXXSUB FOR AR89199
Close Window
Catalog: 1901 | Grid: 0 | Section: 60 | Page: 490
Page Name:TELESCOPE AND TILT STEERING
1AL155227Cover1 XXXSUB FOR R47998 OR AL118173; INCLUDES R26282
2R26282O-Ring1 XXX
3R53317Lock Nut1 XXX
412H303Lock Washer1 XXX5/16" (NLR)
5R91298Knob1 XXX(SUB FOR R50871) (SUB L100436 AND R117432)
614H904Nut1 XXX3/4"
7R71650Lock Washer1 XXX(NLR)
8AR78405Steering Wheel1 XXX(SUB FOR T22875, THIS APPLICATION)
9P46402Snap Ring2 XXX
10R51153Sleeve1 XXX
1119H1792Cap Screw2 XXX1/2" X 1"
1212H301Lock Washer2 XXX1/2" (NLR)
13R64704Bushing2 XXX
14R59953Extension Spring1 XXX
1514H1076Nut1 XXX3/8"
1612H304Lock Washer1 XXX3/8" (NLR)
17AR70442Lever1 XXX
18R58614Spacer1 XXX
1919H1801Cap Screw1 XXX3/8" X 2"
Edited by LNS8310 12/14/2016 23:50
(42501.gif)
(42502.gif)
Attachments 42501.gif (116KB - 730 downloads)
Attachments 42502.gif (85KB - 757 downloads)
