Search Forums | Classifieds (18) | Skins | Language
DEF Injection Failure - Iveco engine
Brandon
Posted 11/12/2016 21:03 (#5633883)
Subject: DEF Injection Failure - Iveco engine
Illinois
I have 40 acres left on a Sunday, and tonight on a Case IH 6140 combine I received an error SCR 007, DEF injection failure. I ran for another half hour or so then began to lose power. I am assuming the engine will derate soon. Is there anything obvious I can check? Any way to get by for another half day?
T800
Posted 11/12/2016 21:17 (#5633906 - in reply to #5633883)
Subject: RE: DEF Injection Failure - Iveco engine
Lee Co
We started having issues with 450 steiner on auger cart.throwing a fault for soot in exhaust. If you shut it off for a minute to re boot computer we can run again until the next fault. Dealer sent in an assist but no help yet.
twraska
Posted 11/12/2016 21:54 (#5633955 - in reply to #5633906)
Wallis, TX
There are 3 filters in the DEF system.  One is a paper element kinda like an oil filter element on a 4 wheeler.  The other two are actually strainers, in a 'housing' on the DEF module.  The first screen will be right there, when you take the housing apart, the other is up in the housing.  Gotta turn your head upside down to see it.  Takes a small pair of needle nose pliers to get it out.  That is the 'filter' that kept stopping up on my machine.  Now if you restart three times with the code up you will derate to idle and have to get a laptop hooked up to remove the derate.
boilerfarmer
Posted 11/12/2016 21:57 (#5633961 - in reply to #5633955)
ECIL/WCIN
Exactly what he said. Third time is not the charm, it is the curse.
3pete
Posted 11/12/2016 23:33 (#5634065 - in reply to #5633961)
WCIN
Had the injection sensor go out on my 8230 during harvest. Derated the engine. Combine out of warranty but there is a 5 year warranty on the emissions crap.
SDman
Posted 11/13/2016 00:07 (#5634079 - in reply to #5633883)
A 6140 would be a TierIVb, so things are a little different than what has been suggested here. On the CNH combines, there is a serviceable prefilter for the DEF system. It looks like a 2-3" long stainless steel filter that has a nut on one end that will allow you to disassemble it so that you can clean it. Take it apart and clean it with deionized water. It should be in the neighborhood of the DEF module(should be shown in your ops' manual as well).
You can check what the pressure of your DEF system is 2 different ways. You can either put it on a "Run" screen on your Pro700 or else you can look at it on the "Combine information" screen on the Pro700 as well. It should be at least 130psi(they usually run 140-150psi during normal operation). See what this pressure is after you clean the filter. The pressure will not build right away on a Tier IVb machine, unlike Tier IVa where the pressure would build up right after you started the engine. If the pressure reaches this spec., the system should fix itself. If it runs too long at too low of a pressure, it will derate itself and need to be reset with a laptop. Good luck!
600QUAD
Posted 11/13/2016 07:32 (#5634278 - in reply to #5634079)
make sure you have a filter on the vent tube of the def tank. it will save you a lot of down time
Bobcat712
Posted 11/13/2016 11:57 (#5634681 - in reply to #5633883)
Have your dealer up the case limp it home kit on, the delete kit, we kept having problems so they deleted it runs like a champ now,
Brandon
Posted 11/13/2016 21:43 (#5635709 - in reply to #5634079)
Illinois
Thanks much for the replies. SDMan, you were spot on. The prefilter was a little dirty, and cleaning it solved the problem. Pressure built to 140 about 10 minutes after start-up, and the error disappeared soon after.
