Search Forums | Classifieds (94) | Skins | Language
New Holland L218 skid steer
hcholsteins
Posted 9/30/2016 21:38 (#5557615)
Subject: New Holland L218 skid steer
So, I made a deal on a New Holland 218 today, was looking for a L220, but looking at a used 220 with low to moderate hours, I could get a L218 brand new last year model(2015) I know the lift capacity is 200 less pounds, so we added a weight lift kit, adding 200 lbs mounted on the back of the 218. It was kind of an impulse buy, as I have been searching for a 220 but came across this scenario/opportunity.  Horsepower is roughly the same.  Am I off my rocker for making this deal?  It will be used for loading TMR, hauling bales(wet/dry) and possibly on a sand shooter.  Any pros/cons you may see in this?  Thanks
Crete
Posted 9/30/2016 21:51 (#5557644 - in reply to #5557615)
Subject: RE: New Holland L218 skid steer
Badger State
You might miss the 220 on the shooter otherwise it won't make much difference. That said we used to have 218s and have all 220s now.
minn gopher
Posted 10/1/2016 04:49 (#5557851 - in reply to #5557644)
Pine City, MN
Don't do a search in here on the NH200's. They haven't been well received.
Jay NE Ohio
Posted 10/1/2016 07:29 (#5558006 - in reply to #5557615)
northeastern Ohio
I have a L218. Never really liked it from day one. It was a first year machine, so maybe that is why it had so many problems. I still don't like it. I now have it on the sand shooter. Needs some weight on the back end.
The rest of my skid loader fleet: L465, LS140, JD 4475 (same as the L465). These little loaders are handy in the barn. I bought the L218 with the hopes of getting a machine that would do more. It's bigger, but not better.
I tried a Kubota 75 earlier this year. It was way more machine than the 218, but didn't quite have the forward reach.
Red Dawn
Posted 10/1/2016 08:45 (#5558131 - in reply to #5557615)
Minnesota
We had a LS 170 and that went to the dealer to get repaired and they let us use a used L220 and that was a night and day difference between those two but when ours got done the dealer ha a brand new 218 there and we traded for that and I thought there was little performance difference between the two such as going into the silage bag and getting a bucket full but other than that we have no complaints about our 218.
IFarmtoo
Posted 10/1/2016 09:23 (#5558199 - in reply to #5557615)
Eastern Iowa
I would have probably did what you did and went with the new machine unless you knew more about the used machine.
You can run the L218 for a while and see if you like and if not you can always trade up , you will have the warranty and a newer machine to trade up with. I think when buying a used skid loader its condition will have a lot to do with the operators which could be good or bad and that is unknown?
