Search Forums | Classifieds (7) | Skins | Language
Case ih 3020 flex header
stevo1440
Posted 9/7/2016 20:34 (#5515690)
Subject: Case ih 3020 flex header
Looking at a 3020 header,please tell me the good and bad about these. Thought i read that they like to drag some when it gets damp out. What options are available.
deereman
Posted 9/7/2016 20:48 (#5515763 - in reply to #5515690)
Subject: RE: Case ih 3020 flex header
NE SD
I ran a 30' 3020 on a 7010 for about 4 years. Head worked great. Yes it did have potential to drag if damp but not anymore than any other head does. I had no trouble at all and I thought it cut very good and fed really good. No it did not cut as clean as some of the newer green heads but I also never really seen any loss of beans left in field either.
Good luck
RBM88
Posted 9/7/2016 21:11 (#5515861 - in reply to #5515763)
scrap iron would not feed drug all the time had to have reel down shattering beans all time auger self destucted twice many more problem
redblooded
Posted 9/7/2016 21:17 (#5515887 - in reply to #5515690)
Shelburne Ontario Canada
Had a 3020 head . Head its self was excellent . Trying to make it feed into a 88 series didnt work.it worked great on the 8010. We had air . Very need bean head . We running draper now biggest advantage is in green straw draper feeds more even
deere44
Posted 9/7/2016 21:53 (#5516046 - in reply to #5515690)
We had two different ones both on a 2388 Could never really get either one to work right. One would plug between auger and feedhouse. The other would drag. Try to get one where you can adjust tension on floor from cab. But I cannot suggest getting one.
hickup1
Posted 9/8/2016 20:44 (#5517920 - in reply to #5516046)
Eastern ontario
have owned 3 of them and am very happy with the performance. did put air bars on all of them. they are all 25 ft. did have one snap inside the auger tube near the end of the finger drive. needed a new auger by the time it was done as they would not warranty at fist so did some welding. caused more damage. in the end dealer came through for half. running on 5088's. would reccomend
