AgTalk Home | ||
IH 1066 - No steering = Cured ! Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Deere Meat |
I should check out this older IH 1066 steering. The steering quit suddenly, but I think the TA still works. So I am thinking the pump is still working. What are the first things you would check ? Edited by Deere Meat 8/3/2016 22:53 | |||
cornerpost |
SE MN Still in Pothole Country | If sprag is good loss of hydraulic pressure means no high side of TA but will still pull in low side. But hold back will be lost in low side | ||
dragon71 |
Farming in NW Iowa | Did you also lose power brakes and does the lube light stay on? If so you have a bad pump or the pto gear splines went away. | ||
1066smoker |
Frederick, Md | Locked up tight? If so hand pump. Not many choices here, 2 pumps or cylinder up front. | ||
tractor5488 |
Stamford Texas | If everything else is working check flow divider valve. | ||
Deere Meat |
Hmmm. Good question. I will have to check some things out. I thought the TA & brakes worked normal & lube light was out. Will Check. Thanks for the tips, Ya'all ! | |||
honest abe |
midwest | where is that on a 1066. worked on them for years and you just threw me because I didn't know they had one. where is it ? | ||
dragon71 |
Farming in NW Iowa | In the mcv. Edited by dragon71 8/3/2016 09:56 (IH MCV 001.jpg) Attachments ---------------- IH MCV 001.jpg (171KB - 74 downloads) | ||
Deere Meat |
Any chance it could have been air? Or a stuck flow divider, maybe? Its working just fine now! I will let it work till it quits again. Thanks for all your input, guys! | |||
honest abe |
midwest | sometimes when the filter gets plugged it will run on start up til sucks tight.. do change filter and inspect that can be minutes or longer | ||
(Delete cookies) | |
