Search Forums | Classifieds (90) | Skins | Language
Can someone run my NH DEF codes?
twraska
Posted 7/15/2016 23:22 (#5413702)
Subject: Can someone run my NH DEF codes?
Wallis, TX
2012 CR 8090 threw some codes then de*rated itself.
First was E-0907-07 DTC:07C
Then E-1757-03 DTC-14F
Then about a minute later SCR 007
A few minutes later E1753-03 DTC-31D
Then finally SCR 008
Dealer said to check filters which were relatively clean.  (Just a couple small bits of trash)
Any ideas?  Dealer is trying to get a mechanic out there but it's Saturday.  ERRRR!
SDman
Posted 7/16/2016 00:03 (#5413738 - in reply to #5413702)
Subject: RE: Can someone run my NH DEF codes?
The E0907 code indicates that the DEF system did not build up pressure after startup. The E1753 fault code indicates that the DNOx module did not power up properly (fuse? IIRC, the fuses for the DEF system are back by the engine around the hydraulic tank). The E1757 indicates the engine is in a derated mode due to the DEF system problems. Not a lot to give you, but its a start. Good Luck!
twraska
Posted 7/16/2016 01:00 (#5413758 - in reply to #5413738)
Wallis, TX
Should have stated in OP....
This  happened after running about 8 hours, engine never turned off.  And,,, according the the diagnostics screen the def system had 72 psi.
