Search Forums | Classifieds (63) | Skins | Language
Which spray tips for gramoxone
ksfarm1
Posted 2/1/2016 19:12 (#5080628)
Subject: Which spray tips for gramoxone
Going to start using some gramoxone this year and was wondering what tips and spray volume others were using. Also if air induction is ok or not.
Tbbt
Posted 2/1/2016 19:43 (#5080732 - in reply to #5080628)
Subject: RE: Which spray tips for gramoxone
ksfarm1 - 2/1/2016 19:12
IMO.
old school
TT @ 20 GPA
if I were to try an AI tip it would be their
TTI twin jet and would still run 20 GPA
for reference I have three different tips on my rig. TT, TTI twin jet, and a Greenleaf TDXL. I run everything from contact to systemic PRE an POST
Edited by Tbbt 2/1/2016 19:45
frank ks
Posted 2/1/2016 20:13 (#5080847 - in reply to #5080628)
edgerton ks.
I run Greenleaf tips , Probably not recommended but work fine for me. I use 18 gallon an acre. I Always use some atrazine or sencor mixed with the gramoxone ,really helps. Always add some surfactant or oil. Only time I have had to respray was a field where I let marestail get to tall on me. I then went back a few days later with Liberty, Talk about a scorched earth spray combo! If you will use plenty of water and use it properly it works well. You may already know but generic paraquat is a 3 lb. product where as true gramoxone is 2lb. Huge cost difference.
ksfarm1
Posted 2/1/2016 20:48 (#5080980 - in reply to #5080847)
Thanks for the replies do you guys use fine droplet size or a little bigger to help drift
jd4930
Posted 2/1/2016 21:02 (#5081034 - in reply to #5080980)
Central ND
We use our twin flat fan nozzles, the same we use for our fungicide work.
lawfarms
Posted 2/1/2016 21:35 (#5081143 - in reply to #5080847)
King City, Mo
frank ks - 2/1/2016 20:13
Good advice
Dave Seck
Posted 2/1/2016 23:12 (#5081381 - in reply to #5080628)
SC Kansas - Hutchinson
The hypro guardian air tips are the best all purpose tips on the market imo
bcochran79
Posted 2/2/2016 05:42 (#5081527 - in reply to #5080732)
South Georgia
+ 1
