Deere or Shoup disk openers for JD XP units?
badgerguy
Posted 1/10/2016 16:24 (#5026009)
Subject: Deere or Shoup disk openers for JD XP units?
S WI
Need to replace the disk openers on my XP units. I have always put the Deere blades on in the past. Wondering if others have had good luck using Shoup replacements.
Haakfarm
Posted 1/10/2016 16:41 (#5026067 - in reply to #5026009)
Subject: RE: Deere or Shoup disk openers for JD XP units?
SC north dakota
Wondering the same thing myself. Price for deere part number AA65248 is 41.95 and shoup replacement is 29.95. I would like to save the money if I can get the same acres on them. Is there an other co. that makes them better than deere?
feeb
Posted 1/10/2016 16:53 (#5026108 - in reply to #5026009)
central pa.
Nothing wrong with shoup openers been using them for years.
jd4930
Posted 1/10/2016 16:55 (#5026116 - in reply to #5026108)
Central ND
We have used nothing but shoup for as long as I can remember
al62
Posted 1/10/2016 16:59 (#5026122 - in reply to #5026009)
Northern WI
The openers from shoup have worked well for me...as good as Deeres.
cottonhauler
Posted 1/10/2016 17:13 (#5026166 - in reply to #5026122)
Zabcikville, TX
Shoup. No questions asked. Many folks around here (and probably there too) using Shoup. High quality parts (most better than what dealer offers) for a smaller price. We just purchased 48 discs and 24 sets of scrapers for a Kinze 3700. About 60% the cost of dealer.
Snafu
Posted 1/10/2016 17:23 (#5026192 - in reply to #5026166)
kansas/nebraska border
Anyone else having the bearing go out before disk are wore down .was going run my another year but 40% of the bearing were out. These were JD
Duane in ND
Posted 1/10/2016 17:29 (#5026200 - in reply to #5026192)
North central North Dakota
Snafu - 1/10/2016 17:23 Anyone else having the bearing go out before disk are wore down .was going run my another year but 40% of the bearing were out. These were JD
I had gotten some very cheap blades and bearings on a planter once from a planter jockey that have now started to fall apart.  The bearings have been going out before the disks are worn out.  I am going to just buy more Shoup ones. I did buy some bearings and rivets and replaced a few but it was a lot of work to get some more life out of a disk blade that probably will be worn out very soon.
Took out my scraper assembly also when disk came off.  Good thing I didn't drive over the disk.
Edited by Duane in ND 1/10/2016 17:32
(20150601_150425.jpg)
(20150601_151724.jpg)
Attachments 20150601_150425.jpg (202KB - 73 downloads)
Attachments 20150601_151724.jpg (118KB - 67 downloads)
deerefriend
Posted 1/10/2016 17:30 (#5026201 - in reply to #5026192)
SE South Dakota/ SW Minnesota
Shoup
Gramps18
Posted 1/10/2016 18:32 (#5026387 - in reply to #5026201)
Kansas
We have run both and the Shoup is just as good or better and less money.
biggrntractor
Posted 1/10/2016 18:51 (#5026442 - in reply to #5026387)
Northern Illinois
Shoup also has the titanium scraper for Deere which we have also used with excellent results.  Shoup usually offers 10% off at the NFMS. You then take those savings and invest them downtown site seeing after the show.
Also Shoup is offering disc blades for the 63 and 64xx Sunflower soil finishers. We get all our flangett bearings for the reels and disc gangs on the Sunflower (we get the better quality option). Their spike harrow parts will also work on the Sunflower. We ran some poly wear pieces they are working on for Drago this fall.
jd7810
Posted 1/10/2016 21:16 (#5026934 - in reply to #5026192)
210 Industrial Dr., Arlington Wisconsin 53911
Working on 1750 6 row. JD blades are good at almost 15" diameter but 10 out 12 blades have loose bearings. Just put on all new Shoup.
KMech
Posted 1/11/2016 06:15 (#5027335 - in reply to #5026192)
Missouri
Check that your blades aren't shimmed too tight. That is the most common cause of early bearing failure. When in doubt, blades are better set on the loose side. The side load when in-soil will still keep them tight, without shortening bearing life.
jd7810
Posted 1/11/2016 21:30 (#5029469 - in reply to #5027335)
Thanks for your comments. Had 6 to 7 shims on each blade where I usually find them. I set the blades at 2 inches of contact using printer paper not business cards as I've seen recommended. I noticed the row unit shanks had cracks just ahead of rear close wheel housing. This tells me the planter is planting around sharp corners putting stress on the blades.
