south central kansas | I have asked this before but still have not found what Im looking for so will ask again. Does anyone make a pto hydraulic pump that goes on the large 1 3/4 20 spline shaft? I can only find ones that go on 1 3/8 21 spline. I find in hard to believe there's not one made. I seem to be as good at finding stuff on google as I am finding stuff in the fridge. lol .I'm looking for one with at least 25-30 gpm flow but 45-50 would be great. Wanting to convert my BBI fert-lime spreader because my tractors hardly have the flow to work, Im getting by but am afraid im starving something. I don't want to use a pto shaft because of all my sharp turns and roungh terraces. Thanks in advance 4640 |
Sac & Story county IA | Pump doctor idea and plain pump work? |
SE, Tn. | I am ruunning a 3600 Kinze bulk fill planter off of one of the pump doctor and it is working very good. The first year it was a little hard to get it hooked up right, but last year it worked real well. We have a 7120 that we plant with and I was afraid it did have enought hydrual to run everything. |
WC MN | Have a pump doctor pump and reservoir I'll sell. |
south central kansas | Anyone have any pics of a pump doctor setup? Never seen one so not entirely sure how they work. thanks 4640
Edited by 4640 1/10/2016 15:08
Dallas Center IA 515-720-2463 | http://www.commandhydraulics.com |
Trenton, KY | Look up GNL Engineering. They sell a PTO pump mount that is similar to the Pump Doctor, and there are PTO Pumps out there for all kinds of flows. |
Corpus Christi, TX | I can't remember for sure but I think Prince makes one. It would be a rather high volume pump. |
Missouri | The OEM pumps used on Kinze planters come as a bare pump, and then one has to special order an adapter from that pump to the intended tractor. (Pump mount adapters come from GnL Engineering.) Every one I have seen has been the big 1000 PTO, (although it's a made to specific fit, so it was designed to match what I found on that tractor). I'd check with GnL. I'm not certain of their contact info, but surely google will yield results. |
