Search Forums | Classifieds (41) | Skins | Language
Hardi sprayer
NEIndiana
Posted 1/9/2016 17:18 (#5023959)
Subject: Hardi sprayer
Columbia City, Indiana
Looking at possibly buying a Hardi Commander Plus 750 with HZ Eagle booms and pulling it with my 4755. Farm about 380 row crop. One owner sprayer in very good condition, local family I know well who takes excellent care of their machinery. They bought it new and upgraded to a SP. This model of sprayer is listed on tractorhouse for a couple thousand than we are talking about on it, but they also offered to help me set it up, calibrate, etc.
Never done my own spraying, but everyone says it's a great ROI to own a sprayer. Not going to lie, it makes me nervous because that is a pretty important job and if I made a mistake it could get expensive in a hurry.
What say you?
Jmark71
Posted 1/9/2016 17:32 (#5023994 - in reply to #5023959)
Subject: RE: Hardi sprayer
Kentucky
The Commander is a really nice sprayer and your 4755 is a lot more tractor than you need. I pulled a 1200 with a JD 7410.
Maynard
Posted 1/9/2016 17:46 (#5024017 - in reply to #5023959)
NE Nebraska
I've had a Hardi for a while, been a good sprayer, just wish I had a dealer closer!
WildBuckwheat
Posted 1/9/2016 18:14 (#5024072 - in reply to #5023959)
Middlesex County, Ontario
Knowing where its from, getting the help on setup, calibration, having someone you can call if you have a head scratcher, and probably getting a box of spare parts would be worth a couple thousand I think. Mostly in the knowing that it came from a good home.
NEIndiana
Posted 1/9/2016 18:27 (#5024098 - in reply to #5024017)
Maynard - 1/9/2016 17:46
Another good thing is we have a good dealer in our small town.
Golden Farms
Posted 1/9/2016 19:06 (#5024172 - in reply to #5024072)
Montevideo,Minnesota
+1 plus you said you have good dealer close by.
I have a Hardi sprayer now and my only regret is that we didn't have one years ago.
You will be happy with it.
Good luck!
NEIndiana
Posted 1/9/2016 21:53 (#5024511 - in reply to #5024172)
Thing that makes me nervous, especially with a pull type, is I have a lot of rolling HEL with waterways that would be pretty tricky to spray with a pull type.
Schmerko
Posted 1/9/2016 22:17 (#5024546 - in reply to #5024511)
East Central Iowa
We have some pretty good hills, some terraces, tile outlets and a few strips with lots of waterways and we make it work with our Hardi Navigator 4000 and 80' booms. Its not as fun or as fast as spraying flat square fields of course.
You don't have to fill the tank all the way when doing those types of fields. It helps to have 5 to 8 sections on the sprayer and auto-swath to turn on/off as you enter waterways at an angle, etc. Often we will drive down the middle of a waterway on a slope, turn the middle sections off (we have ten foot sections so can match up with a 20' or 30' wide waterway) and spray the edges of the waterway.
Previous sprayer was single tires on 120" spacing. Current sprayer has duals at 60" and 120" and it holds the row in the hills better. NORAC on the booms helps too but used to adjust boom heights and angles manually.
ajj0034
Posted 1/9/2016 23:01 (#5024602 - in reply to #5024546)
Nw iowa
Great investment if don't have a gps mapping I would definitely invest in one you don't need to spend ten grand on one buy used or get a older model will help you a lot. It makes it much easier to see where to shut stuff off or if you miss a spot
Brassring
Posted 1/10/2016 06:16 (#5024746 - in reply to #5024602)
Subject: your not close to a JD dealer
St.Clair Co. IL.
My hardi dealer is my JD dealer, they have or can get anything I needed.
as for as hills and waterways, just spray around the waterways first maybe not the full with but some don't be afraid to make mistakes as long as their not BIG ones LOL
and I'm sure before the first season is over you will be asking yourself why didn't I have my own sprayer before.
I'm sure your custom sprayer didn't spend too much time getting the waterways and corners sprayed correctly.
I know the local custom sprayers didn't waste time for corners and edges of waterways that took too long and they had lots of acres to cover.
good sprayer good luck
Bob
AGB
Posted 1/10/2016 06:37 (#5024761 - in reply to #5023959)
Mid-Michigan
I'm on my second hard I. Been very happy except for parts. Many are hard I dealer only and expensive. Spraying is an important job. If they will help you get started and you know how they take care of things, I'd go that route.
4020panther
Posted 1/10/2016 07:43 (#5024845 - in reply to #5024761)
Center Valley Wisconsin
Started spraying when I was in my teens always pulled a simple smaller sprayer. Had a 300 gallon hardi for a bunch of years, 3 years ago bought a hardi 750 commander plus from a dealer. Sprayer is excellent condition and I've got zero complaints on any hardi sprayer I've used. Never needed much for parts and dealer support has been here. If neighbor is helping you set it up you have nothing to worry about. Pull mine with 4455 mfwd.
Fayette Farmer
Posted 1/10/2016 08:07 (#5024895 - in reply to #5024761)
Southwest Central, Ohio
Everyone gripes about the price of hardi parts , how many parts can you get at TSC for a Hagie ,row gator or John Deere ( except nozzles ) ? I hate the price of parts as much as the next guy but have to go to the dealer for all most all combine and tractor parts ( unless you run a M farmall) . Get a dealer you can work with ,keep a few spares and try not to run in to any thing you'll be fine.
Edited by Fayette Farmer 1/10/2016 08:08
