Removing fuel injection pump ,cat 3208
culter
Posted 12/8/2015 20:45 (#4947836)
Subject: Removing fuel injection pump ,cat 3208
s.w. Wi.
I think I got everything ready to remove the injection pump on my cat 3208, but don't have the tool to get the drive gear loose. Anyone know a good way to get the gear loose without the "cat" puller.
Also I have the engine at TDC and the pin in the injector pump notch: Is that all I need to keep it in time?
2strokedd
Posted 12/8/2015 21:03 (#4947893 - in reply to #4947836)
Subject: RE: Removing fuel injection pump ,cat 3208
By having the engine on TDC does that mean you have the bolt out of the front cover and screwed back in the timing hole into the camshaft . You can remove the gear without the puller but it is a tapered fit and stuck on very tight .I believe it takes two 1/4 inch coarse thread bolts to screw into the gear and a round steel plate with holes for the bolts and a hole for the pusher bolt. the 1/4 inch bolts have to be hard or they may snap off .
4WD
Posted 12/8/2015 21:21 (#4947961 - in reply to #4947836)
Between Omaha and Des Moines, 7 miles South of I80
This one might be cheap enough to buy = your choice.
http://www.apexinds.com/tools/M10070.html
Now, I don't know why CAT when to such an "indepth" tool (new style), when the old style WITH correct bolt lengths and Grade 8 bolts were used, worked perfectly fine for many years.
I don't have a good picture, of the old style, but is was basically just a "two-step" round chuck of metal, with two outer horseshoe shaped grooves, cut out for the small grade 8 bolts to fit into = you just removed original tach drive bolt, installed this "two-step" spacer, then finger tighten the 2 - "correct length" grade 8 bolts, then slowly snugged them up evenly until gear popped loose. As said earlier, You must use good bolts AND have good thread engagement BEFORE you start to tighten, BUT bolts can't be too long or will bottom out.
(newer style 3208 gear puller tool.jpg)
(old style 3208 pump gear puller with grade 8 bolts.jpg)
(Picture of old style 3208 injectio npump gear puller.jpg)
Attachments newer style 3208 gear puller tool.jpg (4KB - 1599 downloads)
Attachments old style 3208 pump gear puller with grade 8 bolts.jpg (18KB - 1776 downloads)
Attachments Picture of old style 3208 injectio npump gear puller.jpg (32KB - 1877 downloads)
culter
Posted 12/9/2015 09:08 (#4948632 - in reply to #4947893)
s.w. Wi.
I turned engine until 1/4" rod would go in slot of injector, then went around to crank to see about putting bolt in there. Couldn't get to that spot, but saw that the engine crank was showing TDC on crank shaft position indicator. Will that work?
culter
Posted 12/9/2015 16:11 (#4949196 - in reply to #4947961)
s.w. Wi.
Thanks for all the pictures.
I finally just took a piece of 5/16 steel and drilled two holes in it. Put over hole tightened the bolts and it popped right off
lsweddle
Posted 12/9/2015 19:16 (#4949630 - in reply to #4948632)
Morgantown, Indiana
I would put the bolt in to the cam to make sure it does not move when installing the pump. you do not want the timing off any
