Search Forums | Classifieds (100) | Skins | Language
Semi truck differential locks
Lost farmer
Posted 12/2/2015 20:23 (#4934718)
Subject: Semi truck differential locks
Wood lake,mn
Can you add on a differential lock to axles of a truck? Already have the power divider lock looking to add on differential locks to the axles. Is there some aftermarket company that has a kit to put in or even a limited slip version.
Posted 12/2/2015 20:38 (#4934770 - in reply to #4934718)
Subject: RE: Semi truck differential locks
I added diff locks to my truck. I was changing rear-end ratios anyways, so got the gears and carrier with locking diffs. Depending on how old your truck is, you may have to notch out a place where the carrier bolts into. You also need to get a new axle with longer splines for the collar to slide on. I didn't think it was a huge project.
Trucker1
Posted 12/2/2015 20:43 (#4934788 - in reply to #4934718)
Sparta, WI
I've done it before. You need a new diff head. Can't just add the locker part. As mentioned the axle housing may have to be notched, not really a big deal, just need a torch and grinder. You will also need a new axle shaft as the locking one is double splined.
Get the model number of your diff and look for used or reman units in your ratio with a locker. Going to spend around 3 to 6K to do both axles depending if you go used or reman.
Edited by Trucker1 12/2/2015 20:50
runningbehind
Posted 12/2/2015 21:02 (#4934853 - in reply to #4934718)
NC ND
My rearend guy adds a "no slip" to my rears when I have then worked on. I only do the rear axle, he says most every farm truck he works on puts them on. Parts is about $800. IIRC
It locks automatically when spinning.
hillfarmer
Posted 12/2/2015 21:16 (#4934900 - in reply to #4934853)
runningbehind - 12/2/2015 22:02
would that be what they call a "Detroit locker"
farmboy1492
Posted 12/2/2015 22:31 (#4935137 - in reply to #4934718)
MW farms
Posted 12/3/2015 00:31 (#4935270 - in reply to #4934900)
hillfarmer - 12/2/2015 21:16
A Detroit locker is different then a limited slip or posi rear end. Detroit locker is locked all the time and comes unlocked when turning where a limited slip only locks when one wheel spins faster then the other causing the clutch pack on it to tighten up from centripical force and provide power to the opposite wheel. Clear as mud? :)
hillfarmer
Posted 12/3/2015 02:29 (#4935297 - in reply to #4935270)
I see
