Search Forums | Classifieds (51) | Skins | Language
Geringhoff corn recommended RPM
case14
Posted 10/10/2015 11:16 (#4832757)
Subject: Geringhoff corn recommended RPM
MN
What does Geringhoff recommend to run their rotodisc corn head at for rpm? I have the little monitor in the cab that tells me shaft speed along with deck plate position.
Service line is busy.
Thanks for the help.
case14
Posted 10/10/2015 11:26 (#4832766 - in reply to #4832757)
Subject: RE: Geringhoff corn recommended RPM
MN
750 to 780 is what gerringhoff called me back with.
Vigarfarms
Posted 10/10/2015 12:13 (#4832815 - in reply to #4832766)
rochester IN
We're running north star 820 I believe
jcfarmboy
Posted 10/10/2015 12:24 (#4832828 - in reply to #4832757)
South Western Ontario, Canada
When the rpm on display flashes its not "in the operating range"
Lowyielder
Posted 10/10/2015 13:13 (#4832881 - in reply to #4832757)
I run the NS at 620 to reduce butt shelling
minnmc
Posted 10/10/2015 17:36 (#4833095 - in reply to #4832757)
west central MN
Running 620 here at 5 mph. If going slower, I turn it down
Redshale1
Posted 10/10/2015 18:28 (#4833127 - in reply to #4833095)
Northeastern Pa
I'm at 500. Replaced crown gears to slow it down. To much but shelling in dryer corn. This is on a roto disc
Scillfarmer
Posted 10/10/2015 19:49 (#4833221 - in reply to #4833127)
southern edge of central illinois
I agree. Bout 500 here.
kritzy
Posted 10/10/2015 20:02 (#4833241 - in reply to #4833221)
red river valley se of fargo
Hmmmm, I'll have to play with mine a little. We haven't started corn yet but if I recall correctly, we were running around 900 rpm, ground speed 6-6.5 mph.
