| Purchased a new old stock 3020 head from an equipment jockey and are having some problems getting it set up. The main problem we are having is getting it to cut and not push trash and then dirt in front of the cutter bar. We have tried three different header pitches and finally have it set at approx. 15 degrees right now, timed the cutter bar because it was off 1/4 to 1/2 an inch, tried different things with the reel but none of it seems to have completely fixed the problem. It also has hydraulic adjust on the torsion springs which we have tried in several positions and tried to make sure they were adjusted evenly across the head. Doesn't seem to have one place it likes to push the whole head can do it at different times. Driving on an angle helps to a point. Timing the head seemed to improve the cut so that during the day when the sun is out and you keep it under 3.5mph your good. Have tried messing with the sensitivities and height of the head to no avail. The beans have some green in them but they are testing 11-13% moisture. However when the sun starts to go down you might as well go home it just wants to push trash. Head is on an 8120 and was wondering what speed we should run the feeder house? Neighbor has one and seems to get along with it and he even runs some double crop beans with his which can be challenging. Keep thinking it has to be something simple. Any help is appreciated as long as it doesn't involve telling me I need a $80,000 draper. |
 n.c.iowa | what speed you running feeder house at? and how old is it? |
Shelburne Ontario Canada | U did the dealer setup? Ours there was a rubber block bushing the header float torqued thru . On back side of head there are bout 5 threaded rod things wich u adjust with a 15/16 wrench . Have one guy on front by knife . With head raised up at waist hi the knife should have (i think it was 2-3" ) travel down against the stop .(from where it is push down with hand and let it bounce back up, then push down again and measure how far u push down against stop) If this is set wrong header puts to much force down on ground an shoves dirt |
WI | Angle should be 15-16 degrees on 3020 head. Get smartphone app and check it. |
| I would make sure the Pro 700 head setup is done properly. Maybe the float option isn't set properly. I had the same problem on my 8010 and figured out the head wasn't floating. |
| Check the hex shaft on back of head. Mine had sat on dealer lot for over a year and some of the shafts were stuck in the bushings. The were twisted and wouldn't flex. I fought mine the first year shop was out 4 times to try to get it to work. Tried all kinds of things never got it to work. After season I went to another dealer to trade it off. Salesman asked why I wanted to trade . I told him about the pushing. He said I know what is wrong lets talk to shop manager. Shop manager said you hex shafts are twisted. Went home and looked at head. 6 were twisted. Dealer fixed under warranty. Worked great second season. Last field last year starting pushing, sure enough 2 were twisted. Head had sat about a week because of rain.
Edited by Mnsidehill 9/19/2015 07:51
| We have at least two shafts twisted and they are both the center shafts. They don't seem to want to move but its not where it necessarily wants to push but will check the others. What was the fix for getting them freed up? |
| Feeder is running at 560 and speed has to be kept under 3.5 during the day with full sun and a breeze. Sun down forget 1mph still wants to push. Have tried as low as 460 on the feeder. |
| Thats where it is set. |
| Ours was sitting at the factory for going on 3 years now possibly might be the part of the problem. THanks |
| add more springs under it. as far as im concerned they suck. you answered your question to start with
| If any shafts are twisted the hyd adjust will not adjust the other shafts. If they are twisted they need to be replaced to work. They are not easy to get apart. One dealer said they had some of the heads that the center two were twisted during shipping . |
| I can understand the head won't adjust evenly but the way it is made I can't see why it wouldn't adjust the rest there independent? |
