Search Forums | Classifieds (10) | Skins | Language
blocking fifth wheel up for end dump
long_johns
Posted 9/3/2015 16:12 (#4768549)
Subject: blocking fifth wheel up for end dump
Eastern Kansas
anyone have any pictures of what they use to block their fifth wheel up for a end dump? Need to set a truck up to pull a 1/4 frame end dump. truck is mostly used to haul grain. Thanks.
farmrboy
Posted 9/3/2015 20:46 (#4769074 - in reply to #4768549)
Subject: RE: blocking fifth wheel up for end dump
Southern Illinois
Yea i can get you some pictures tomorrow i've got one unhooked right now. We had the local welding shop do this one due to time issues but it don't take super long to do it. The way he does it is pretty simple so you can unpin it if you need to pull another type of trailer.
farmrboy
Posted 9/4/2015 10:01 (#4770145 - in reply to #4768549)
Southern Illinois
Here's some pictures for you I can get you more if you need. You can put a cotter key or bolt in the one end to keep the pin from coming out and use Schedule 80 pipe
Edited by farmrboy 9/4/2015 10:06
(image.jpg)
(image.jpg)
(image.jpg)
(image.jpg)
Attachments image.jpg (95KB - 1429 downloads)
Attachments image.jpg (111KB - 1316 downloads)
Attachments image.jpg (102KB - 1318 downloads)
Attachments image.jpg (114KB - 1257 downloads)
limespreader22
Posted 9/4/2015 11:13 (#4770244 - in reply to #4770145)
SE Illinois
We had 2 of our trucks pinned using the same welding shop as these pictures. They have held up good and are very easy to switch back to a trailer that doesn't require it. Simply pull the bar out and your ready to go. Edited : I found a picture of the pin we use on ours.
Edited by limespreader22 9/4/2015 11:15
(IMG_20150904_105428627.jpg)
Attachments IMG_20150904_105428627.jpg (123KB - 1310 downloads)
