Search Forums | Classifieds (37) | Skins | Language
JD 2955 shifting problems
armsteadc
Posted 8/19/2015 10:46 (#4741582)
Subject: JD 2955 shifting problems
I have a JD 2955 (1985 model I believe) with a cab. When shifting gears, it grinds them really bad and usually takes a couple of tries before you can get it in a gear. It does not matter which stick you try to put in a gear first (whether it be the hi/lo stick or the actual gear stick, they grind either way). Power steering not working right. It is kind of jerky when running. What are your thoughts on what's wrong and does anyone know a guesstimate on cost to fix?
JohnW
Posted 8/19/2015 11:06 (#4741606 - in reply to #4741582)
Subject: RE: JD 2955 shifting problems
NW Washington
My first guess is that you have clutch disengagement problems. I am not up on the details but I remember that the hydraulic clutch system on these German JD tractors can be a problem.
The Pretender
Posted 8/19/2015 12:27 (#4741709 - in reply to #4741582)
The Internet
Clutch
560HighCrop
Posted 8/19/2015 12:43 (#4741740 - in reply to #4741582)
west central Iowa
We have 2955 also. There is clutch reservoir under dash cover on left side. Probably empty due to a leak. Book will tell which DOT fluid to use.
dewey_88
Posted 8/19/2015 13:04 (#4741780 - in reply to #4741740)
NEOH
Calls for dot 4.
JDGnut
Posted 8/19/2015 13:57 (#4741856 - in reply to #4741780)
Waxahachie, TX
We have a 2950 and have had issues with the master slave for the clutch, not giving full travel.
Super 65
Posted 8/19/2015 18:11 (#4742173 - in reply to #4741856)
South Central Kansas
X2 on the clutch and if you need to bleed it you will have to figure out a way to push fluid backwards through the system to get the air out. The 2950 also had a slave cylinder that set on top of the transmission that was hooked to the clutch system. It can leak fluid also and needs to be bled with the rest of the system. Don't know if the 55s have that also.
