AgTalk Home | ||
JD 6410 loosing fuel prime Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
pepr |
West Central Arkansas | Have 1999 JD 6410 with just over 1600 hrs. Tractor starts almost immediately, but it will shutdown very soon after started if setting for a day or so. I suspect that a check valve is leaking resulting in a loss of prime. Please share your thoughts. | ||
Virginia Veg. |
Eastern VA. No such thing as too many Magnums. | Put a check valve between the tank and fuel filter. It's a known, common problem and an incredibly simple fix. It's actually in the 6410 parts catalog. | ||
Virginia Veg. |
Eastern VA. No such thing as too many Magnums. | It's item 8. Part# AL117189 (image.jpg) Attachments ---------------- image.jpg (116KB - 93 downloads) | ||
J & R Ranch |
SE South Dakota | Our 7430 did the same thing, parts guy told me to replace all the hoses from the the fiber/rubber to all rubber hose. Long story short that did it. They didn't leak but were always dusty and that let the fuel drain back. Edited by J & R Ranch 7/20/2015 19:29 | ||
Virginia Veg. |
Eastern VA. No such thing as too many Magnums. | All you needed was the check valve. | ||
Moe Syslak |
The rapidly vanishing farmland of Boone Co. Ind. | If it has the factory hoses, replace them. Deere put crap hoses on those for a few years. Small cracks let air in. | ||
40/20vision |
NCIA | +1 on replacing the hoses. I also replaced them cheap pinchy type clamps with real hose clamps. Had same issues here. No more. | ||
Plierswearer |
Midwest | X3 Replace hoses. | ||
redoak |
deep SW On. | Our 6210 ('99 model) does that , just turn key on for 5 seconds before starting,problem solved-Were did you find such a low hr. 6410 --those 6x10 was/is best ractors deere ever built | ||
simscott |
Dalhart Texas | It must have been a problem over several years. Our 6430 had hell with cheap leaky fuel lines. The hose got hard and brittle. would let air suck into fuel lines I guess. Several service calls, I think there was a PIP at end when traded it to replace all hose. | ||
boutbrok |
NE Ga | Had to replace check valve and fuel lines on '01 6310 at about 3 years old. Used fuel line from NAPA. Had to get short hose between filter and pump from Deere. 1700 hours on tractor now. | ||
(Delete cookies) | |
