Search Forums | Classifieds (124) | Skins | Language
Deere 6620 Titan II Combine Year?
JEC_62
Posted 6/19/2015 07:31 (#4635132)
Subject: Deere 6620 Titan II Combine Year?
West Middletown
I just recently purchased a John Deere 6620 Titan II Combine.
The John Deere website shows the Serial # running from 000001 to 611,xxx. Other sources on the web seem to indicate these Combines were made between about 1979 and the late 80's.
My Serial Number 610,123. Does anybody know how to determine the year of manufacture??
Dan
Posted 6/19/2015 07:57 (#4635193 - in reply to #4635132)
Subject: RE: Deere 6620 Titan II Combine Year?
My book says late 1984......  1985 beginning with 610,301.
jfg5
Posted 6/19/2015 08:43 (#4635267 - in reply to #4635132)
Titan II's were marketed from 1985 thru 88'. In 89 JD went to the 9x00 series. I had a 1985 6620 but I am unable to help with the serial #. A titan II will have a green (not a yellow) cab roof.
WItitan2
Posted 6/19/2015 09:13 (#4635310 - in reply to #4635267)
Pierce county WI
I believe they made the 6620t2 into 89 for the sidehills. Serial # 610301 and up should be titan 2. Tailings elevator, sieves look different.
JD 9400
Posted 6/19/2015 11:37 (#4635481 - in reply to #4635310)
Southern Pa.
WItitan2 - 6/19/2015 09:13
1988 was the last year of the XX20 series combines, except for the 6620 sidehill which was kept for one more year. Titan ll combines have longer sieves, (I think, correct me if I'm wrong), they definitely have a tailings elevator setup similar to the 9000 series, a green roof, and the chaffer/sieves were sped up. (Walkers too??) This was to help increase capacity.Some folks change them back to the slower speed to help lengthen shaker bushing life.
I don't know if it's makes a big difference in reliability/capacity or not,or how big a deal it is to change it back. Maybe someone else can help you with that information.
Used to own a 6620. It did a great job for a combine that size.
Kinda curious how yours is a Titan ll with the serial number that it has?
Good luck!
motram5455
Posted 6/19/2015 12:37 (#4635557 - in reply to #4635132)
Mid-East Nebraska
6620---- 353901-403300--- -1979 Self Propelled
6620---- 403301-452500---- 1980
6620---- 452501-502550---- 1981
6620---- 502551-551900---- 1982
6620---- 551901-600000---- 1983
6620---- 600001-610300---- 1984
6620---- 610301-615100---- 1985
6620---- 615101-620100---- 1986
6620---- 620101-625100---- 1987
6620---- 625101-630400---- 1988
6620---- 630401-END------- 1989
AVP_Matt
Posted 6/19/2015 17:22 (#4635924 - in reply to #4635557)
Hennepin, IL
Amazes me how they made +/- 50,000 until 1984 when they made 10,000. Then they only made +/- 5,000 the rest of the years. Really shows what was going on in those years.
Wheat77
Posted 6/19/2015 17:25 (#4635933 - in reply to #4635924)
AVP_Matt - 6/19/2015 17:22
I suppose in later years, many wanted more capacity, so the 7720 was most popular, there were
lots of 8820's around here also, not so many 6620's.
WItitan2
Posted 6/19/2015 17:46 (#4635967 - in reply to #4635924)
Pierce county WI
You think that's low, check out production of jd 4050 tractors in like 85 or 86. I don't think they made 50 one of those years. That's when Deere started making motor home chasis, nothing better to build!
