Search Forums | Classifieds (94) | Skins | Language
New Holland l218 starting problems
cmfarmer88
Posted 5/31/2015 12:31 (#4601133)
Subject: New Holland l218 starting problems
My nh l218 skid steer keeps blowing the 25amp crank fuze every time I go to start it. When I turn the key on the glow plugs start clicking but when I turn it on to start, blown fuse. Any ideas what would be causing the problem? Any help appreciated.
ge jr
Posted 5/31/2015 13:51 (#4601273 - in reply to #4601133)
Subject: RE: New Holland l218 starting problems
algona iowa
Had a problem with an l223 blowing fuse ended up being the electric fuel pump not sure if it would be same problem
Jay NE Ohio
Posted 5/31/2015 16:13 (#4601483 - in reply to #4601133)
northeastern Ohio
I have a L218, but have not had that problem. Could be a bad glow plug. Disconnect the wire that runs to the glow plugs and see if the fuse blows. You should be able to test each glow plug with a multimeter if there is a bad one (have to disconnect each one to test).
