Search Forums | Classifieds (32) | Skins | Language
Plastic type on John Deere hood??
poor loser
Posted 5/12/2015 17:16 (#4566324)
Subject: Plastic type on John Deere hood??
north central ky
i got a 7820 with a crack in the hood and i have a welder to fix it but i need to know what type of plastic the hood is to do a good job on it? i looked all under the hood for a code but couldn't find one. TIA
BFarms2
Posted 5/12/2015 19:41 (#4566506 - in reply to #4566324)
Subject: RE: Plastic type on John Deere hood??
I have tried to do some research on this. Talked to John Deere with out much help. I was told some of the early hood were made from a soybeans product then changed later on to correct problems.
One person used 5003 R7
Another person used Xenon 1102 polycarbonate rod and he said it was still holding good.
Hope this helps and you have better luck than I have had trying to figure this out.
I checked all over the back of a hood but couldn't find any codes like other products have.
You might Google these rods and find some information .
If you find any helpful information let me know.
cottonhauler
Posted 5/12/2015 20:08 (#4566559 - in reply to #4566506)
Zabcikville, TX
If the hood breaks, how is the rest of the tractor built??? R&D means A LOT!!!!
Ddd
Posted 5/12/2015 21:09 (#4566720 - in reply to #4566324)
We got somebody to weld on the hoods of our 8330. Not sure what he used. Those hoods are crap. A lot of Deere plastic hoods with over about 4000 hours are cracked. They are really expensive too. Decided the mediocre weld will have to work .
deereboy8400
Posted 5/12/2015 22:08 (#4566870 - in reply to #4566324)
East Central Indiana
I took this pic at a deserted booth at the 2015 Mid-America Truck show in Louisville. It says 8000 hood, but is obviously a 8x20 hood. Manufactured by Sabic, or at least the resin appears to be manufactured by Sabic, i don't know.
Edited by deereboy8400 5/12/2015 22:15
(8020 hood.jpg)
Attachments 8020 hood.jpg (71KB - 641 downloads)
poor loser
Posted 5/12/2015 22:21 (#4566903 - in reply to #4566506)
north central ky
Yes, I finally found the code. It is pc+Pbt, I used a polycarbonate rod and it seemed to weld good and not discolor. I guess time will tell.
poor loser
Posted 5/12/2015 22:23 (#4566913 - in reply to #4566870)
north central ky
Yep, you beat me to it. That is the code that I found and when I looked it up it was called xenoy. Thank for the replies. I just hope it hold because I'm sure that hood won't be cheap.
I was aiming to take a pic after I fixed it but I forgot. I welded it,sanded it, and hit it with a shot of paint and you can barely see it.
Edited by poor loser 5/12/2015 22:27
(image.jpg)
Attachments image.jpg (137KB - 552 downloads)
deereboy8400
Posted 5/12/2015 22:27 (#4566920 - in reply to #4566913)
Please help us out by sharing your welding equipment specs and technique.
Edited by deereboy8400 5/12/2015 22:28
poor loser
Posted 5/12/2015 22:31 (#4566928 - in reply to #4566920)
north central ky
This is the welder I got. It comes with plastic charts and different techniques with different plastics. It also comes with different rods. It has been handy to have, I have fixed corn head snouts and a leaking fuel tank with it and hoefully a hood.
(image.jpg)
Attachments image.jpg (157KB - 557 downloads)
Accidental farmer
Posted 5/12/2015 22:49 (#4566965 - in reply to #4566920)
Way north central indiana
Had a big hole busted in mine and couldn't even find all the pieces. Checked on cost of new hood and you can forget that. Finally took the cheap route and plastered over it with Gorilla tape. Might even spray the repair with JD green this summer.
a4t-1600
Posted 5/13/2015 00:02 (#4567054 - in reply to #4566324)
Dearfield Co.
I asked a rep that services a body shop about it and he recommended a Flexor product. I don't have the tubes any more but it was a epoxy of sort that all the tubes went in the gun like a caulking gun. I didn't like the way it mixed out of the gun so I stirred it better and it worked good. I used the remaining on a ford semi trucks side skirts and it worked there as well. I can't remember if it was a 2 or 3 part epoxy and I can find the gun tonite
kwk
Posted 5/13/2015 00:08 (#4567056 - in reply to #4567054)
BFarms2
Posted 5/13/2015 08:12 (#4567422 - in reply to #4566928)
poor loser - 5/12/2015 22:31 This is the welder I got. It comes with plastic charts and different techniques with different plastics. It also comes with different rods. It has been handy to have, I have fixed corn head snouts and a leaking fuel tank with it and hoefully a hood.
I got the same welder you have at Arizona tools for some cheaper. Where did you find the welding rod? I am not having any luck finding it.
http://www.arizonatools.com/best-sellers/detail/Mini-Weld-Model-7-Plastic-Welder-w/URE5700HT
poor loser
Posted 5/13/2015 13:40 (#4567804 - in reply to #4567422)
north central ky
Mine came with the rods. I used the poly carbonate Rod and it looked good when I got done welding it but it didn't last very long The hood is already cracked againso I'm not sure if that was the right Rod to use
BFarms2
Posted 5/13/2015 14:39 (#4567855 - in reply to #4567804)
poor loser - 5/13/2015 13:40 Mine came with the rods. I used the poly carbonate Rod and it looked good when I got done welding it but it didn't last very long The hood is already cracked againso I'm not sure if that was the right Rod to use
http://www.ebay.com/itm/271362889258
After you said you found the code on the hood I found these welding rods. I am going to order these and see what happens.
I wanted to say there is a body putty for plastic and when painting there is a product called Flex you put in the pains so it will not peal off.
There are some good painters on this forum that might give us some suggestions
Edited by BFarms2 5/14/2015 08:03
Afranks
Posted 3/17/2020 10:57 (#8112513 - in reply to #4567855)
How did your weld repair hold up? Do you have any advice on the repair method to use. I have an 8420 with a 6" crack in the left hand wheel well near the heat shield for the exhaust manifold. Thanks in advance
