NEIN | Anyone use it and what was your experience? I am told it has good residual and I have some thin wheat I am going to keep so we can tile the field that may get weedy. Your thoughts and comments appreciated. |
SWOH | I used it a couple years ago, it held out pretty well and it got everything that was there...mostly winter annuals. Full rate. I'm going to use it again this year whenever it dries out enough. |
perryton, tx | It's kind of pricey compared to some other options. I sprayed one field with it this year based on the recommendation from several posters here that it won't ding the wheat like 2,4-D or Banvel can. I ran the full rate with Ally Extra and was happy with the results but I just had mustards to kill. If you have kochias in particular I couldn't predict how effective it will be. |
N.W. Ohio | Have used it with very good results. Not sure where your located or if you double crop? But if memory serves me right , you can't double crop soybeans after spraying it on the wheat. |
Strasburg North Dakota | I used Huskey Complete on my wheat last year. Worked great but did ding the wheat a little . |
jackson county WI | I didnt have that good of luck with. I was in same situation as you with thin wheat. I had trouble with it sticking in my tanks and lines even after rinsing 3 times with tank cleaner. Rinse well as soon as your done be my suggestion. |
Ns/Tr co. Ks | Never heard of "husky".
It's called huskie.
Edited by 4x2188 4/27/2015 11:55
Mid-Michigan | I have been using it for several years. Been a good chemical for me. |
NEIN | . |
