Search Forums | Classifieds (147) | Skins | Language
8.3 Cummins fuel pump gear problem
9410r
Posted 4/14/2015 17:32 (#4516476)
Subject: 8.3 Cummins fuel pump gear problem
Pa/ny line
Put a new fuel pump on a 8.3 motor. I torqued it to 135 ft lbs and it keeps slipping time. Only slips time when the motor is working hard at full speed . What am I doing wrong ?
scott nelsen
Posted 4/14/2015 17:50 (#4516495 - in reply to #4516476)
Subject: RE: 8.3 Cummins fuel pump gear problem
Leeds, North Dakota
Shaft and gear need to be clean, I use either, if its slipping not a good deal, possible taper is wore, correct torque? Scott.
9410r
Posted 4/14/2015 19:05 (#4516592 - in reply to #4516495)
Pa/ny line
I didn't clean with either.. Will try that. Thanks
Farminmyway
Posted 4/14/2015 19:30 (#4516632 - in reply to #4516592)
Northern ohio
5.9 cummins has same pump and has the spec raised to 185 lb/ft to help stop the slipping
jhrfarms
Posted 4/14/2015 19:32 (#4516640 - in reply to #4516632)
Herrick il
We had the taper not right on one wouldnt hold gear for anything
Austin
Posted 4/14/2015 20:09 (#4516722 - in reply to #4516476)
Garrett County, MD
You can find different torque specs for that nut.
I think the last one i did i tried to torque to 150 but i stopped shy bc i was afraid to strip it.
Ive done quite a few and never had a slipping problem. Just tightening by feel.
Worn taper or not tight enough is all i can think of.
a4t-1600
Posted 4/14/2015 20:33 (#4516794 - in reply to #4516476)
Dearfield Co.
had a rebuilt from a big speed shop that did the same thing. I thought the shaft or the gear was bad and I called and griped . They said locktite it and torque it to 150 and that worked. It was on a 12 valve but the same principles should apply
Charlie Chaz
Posted 4/14/2015 20:38 (#4516822 - in reply to #4516476)
Ive seen this happen if an injector is plugged with debris.
a4t-1600
Posted 4/14/2015 20:59 (#4516896 - in reply to #4516822)
Dearfield Co.
return line as well--------------the pump I did had lasor cuts and some speed secrets creating a higher load
Red wrench
Posted 4/14/2015 23:21 (#4517220 - in reply to #4516896)
South central MN
Could put loctite 609 on the taper as that's what they use on the cam gears on the isx/qsx. As Scott said, taper needs to be clean.
pupdaddy12003
Posted 4/15/2015 05:57 (#4517349 - in reply to #4517220)
NW Central Ohio
...clean shaft, Stud and Bearing Mount Loctite. Should hold it. (Loctite Primer is very good stuff too, helps make a good bond)
