AgTalk Home | ||
7200 max emerge seed population? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Moonlighter |
Randolph county NC | I want to set my planter up plant around 26000 can anyone tell me the gear setting. Somehow I can't find anything in my operators manual. Planter is set on 38 inch rows. TIA | |||||
99MAX |
Stearns County, Minnesota | For finger pickup planters??? Corn-Finger Pick-Up-30 in. to 40 in. Rows
4WD |
Between Omaha and Des Moines, 7 miles South of I80 | Here's a finger pickup chart: (old thread) {Note: Vacuum will be different, so tell us what you have, for a planter = need more description. I know you will be in LOW range with vacuum AT 26,000}
http://talk.newagtalk.com/forums/thread-view.asp?tid=455347&mid=3699453#M3699453 Edited by 4WD 4/11/2015 20:36 | |||||
Moonlighter |
Randolph county NC | Finger pickup | |||||
4WD |
Between Omaha and Des Moines, 7 miles South of I80 | Looks to be : High range, then driver at 24 and driven at 28 = 26,064 ( that's what I see, on the chart) | |||||
Moonlighter |
Randolph county NC | Thanks! How do I know if it is on high or low range. Is there a separated manual that has all this in it. Because there is nothing in my manual about seed population. | |||||
4WD |
Between Omaha and Des Moines, 7 miles South of I80 | 2 sprockets, on left side of planter population transmission are your high and low. When you move the sprocket and chain, to switch from low/high {after you release the side idler spring}, you will notice that the idler bracket rotates to a whole new position AND you need to hook the "spring" into a different hole. Here's some photos, from internet: Edited by 4WD 4/12/2015 07:35 (JD planter transmission.jpg) (JD planter transmission sticker.jpg) (7200 tranny.jpg) (7200_in paint program.jpg) Attachments ---------------- JD planter transmission.jpg (100KB - 758 downloads) JD planter transmission sticker.jpg (93KB - 737 downloads) 7200 tranny.jpg (156KB - 667 downloads) 7200_in paint program.jpg (143KB - 624 downloads) | |||||
Moonlighter |
Randolph county NC | I see it now. Thanks a lot. | |||||
Moonlighter |
Randolph county NC | I'm assuming the larger pulley is high range and the smaller is low range? Is that correct | |||||
4WD |
Between Omaha and Des Moines, 7 miles South of I80 | Nope, smaller gear is high range (notice the sticker on photos, that I added) (7200 tranny_look at sticker.jpg) (7200 tranny_sticker only.jpg) Attachments ---------------- 7200 tranny_look at sticker.jpg (116KB - 719 downloads) 7200 tranny_sticker only.jpg (77KB - 695 downloads) | |||||
Moonlighter |
Randolph county NC | After I left you the last message I went back and looked at that pic and seen it on the decal. Yeah I gotta get me one of those decals. Thanks for all your help today. | |||||
(Delete cookies) | |
