Fuel check valves Cat C-15
mignic
Posted 3/20/2015 21:09 (#4466848)
Subject: Fuel check valves Cat C-15
Texas Panhandle
I'm having trouble with the fuel leaking back over time. The pump looks like it's been replaced and after doing some searching thot I might try changing the check valves first.
I think that there is two. One on front left and one on the right behind the inlet line.
I can't find any good parts diagrams. Does anyone know where to do a cat parts search or which check valves I would need? Thx
(20150318_125114.jpg)
(20150318_125213.jpg)
Attachments 20150318_125114.jpg (98KB - 917 downloads)
Attachments 20150318_125213.jpg (94KB - 800 downloads)
durallymax
Posted 3/20/2015 21:15 (#4466865 - in reply to #4466848)
Subject: RE: Fuel check valves Cat C-15
Wi
parts.cat.com enter your serial number and you can search through the parts.
Just an example from a serial I pulled off interweb NXS. Probably not be the same for yours. No clue if they are your issue either.
Filter Head
Edited by durallymax 3/20/2015 21:19
4WD
Posted 3/20/2015 21:29 (#4466909 - in reply to #4466848)
Between Omaha and Des Moines, 7 miles South of I80
See photo:
(3406E fuel filter base photo_in paint program.jpg)
Attachments 3406E fuel filter base photo_in paint program.jpg (40KB - 943 downloads)
mignic
Posted 3/21/2015 09:43 (#4467534 - in reply to #4466848)
Texas Panhandle
Thanks guys.
